12-12-2010, 04:04 PM | #1 |
yes, i do
cab weight??
ok so my 72 gmc gets to have its turn in the garage soon and i wanna lift the cab off the frame to perform the rust repairs. what i was thinking of doing was getting some pulleys and a winch and lift the cab off the frame that way. the pulleys would be supported by the ceiling beams in the garage (i have an attic space in the garage) and the winch would be bolted to one of the walls. i was thinking of using 4 pulleys to distribute the weight evenly so i can get the cab up off the frame far enough the get something like saw horses under the cab to support it. so how heavy is an a/c auto cab with the tank and bench still in the cab?
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
12-12-2010, 04:30 PM | #2 |
Re: cab weight??
about 250
12-12-2010, 04:47 PM | #3 |
Re: cab weight??
I think your going to need a single pulley to get it to lift straight. you can mount the pulley directly above the cab, and then hook it to the rafters using 4 separate lines. you need to make sure you have clearance above the cab, you will have a lot of loop above the cab
I do not know what a cab weighs, but I think 250 pounds is very conservative
12-12-2010, 05:01 PM | #4 |
Cruzin
Re: cab weight??
the last cab i scraped was around 400 no doors no glass
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-12-2010, 05:04 PM | #5 |
Re: cab weight??
I would plan on about 4 foot of space for the pulley and cables. I have lifted cabs outdoors, I think your not going to have room indoors with a pulley. the problem is the cable has to span the width of the cab, and it makes a V above the cab. you need a way to seperate the cables, and your 4 pulley idea might actually work better now that I think about it, assuming you can make it so all 4 lift evenly
12-12-2010, 05:44 PM | #6 |
yes, i do
Re: cab weight??
well i might just have 4 feet to the ceiling rafters. but i figure 4 pulleys so i can distribute the load evenly so i don't pull the bolts out of the rafters with one pulley. about the only thing that i would really to make sure of is having all 4 ropes/ends at the end come up even. but i will have to see what i can come up with. the biggest reason for wanting the 4 pulleys aside from weight distribution is i don't know if i have a rafter that will run straight through the middle of how i part my truck in the garage. i'll just have to take a look when i get home tomorrow. right now i'm down in jacksonville florida for pilot/aircrew training. i'll let ya'll know what i come up with after i get home. i'll have 2 days off so i'll see what i can get to work. and if this does work then i might be able to use it for taking the bed off too!
12-12-2010, 09:35 PM | #7 |
yes, i do
Re: cab weight??
going with the one pulley idea, i found this on ebay. does this look like it would work? and this way i can still attach 4 ropes/straps.
http://cgi.ebay.com/HD-3-WHEEL-ROPE-...item45f77394c3
12-12-2010, 09:44 PM | #8 |
Re: cab weight??
when I lifted a cab, I used a single lift point and it took about 10 foot from the I beam to the ground to have room to clear the frame so I could roll it out. I looped a strap through the window opening and used a 2x6 laid flat across the room to keep the strap from damaging the cab.
12-12-2010, 09:50 PM | #9 |
yes, i do
Re: cab weight??
ok. well i don't plan on rolling the frame out. just lifting it 1-2 feet from the frame so i can work on the underside of it so i can replace the cab mounts/supports
12-12-2010, 09:58 PM | #10 |
Re: cab weight??
here is a picture of my cab lift. I was changing cabs by myself.
12-12-2010, 10:27 PM | #11 |
fat old dude
Re: cab weight??
i used 4 friends =]
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
12-12-2010, 11:06 PM | #12 |
Old Skool Club
Re: cab weight??
I would think that even 400-lb estimate is on the shy side. The glass is heavy. Lifting the cab w/o the doors is how we lifted one that I got. You gotta get the windshield/firewall closer to the lifting device, or that part will tilt downward if you are lifting like I did with a 4x4.
Be careful.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-12-2010, 11:13 PM | #13 |
Re: cab weight??
12-12-2010, 11:53 PM | #14 |
yes, i do
Re: cab weight??
or the room to just separate the cab from the frame and have the frame outside.
12-12-2010, 11:56 PM | #15 |
Re: cab weight??
you should have seen the entire picture. i took the cab off the truck on the left first, it was junk. they I rolled the chassis with a good cab up until the front bumpers touched. I did this by myself, using a 72 3/4 ton to push and pull. I chained the front bumpers together. then I lifted the cab up, and pulled both trucks at the same time. set the cab down on the good frame, and shoved it back in the parking spot. I took that picture when I stopped to rotate the cab
12-13-2010, 07:43 AM | #16 |
Re: cab weight??
if the box is off the frame it might b alot easier to just lay the cab on its back than lifting it up/or if motor and front clip is gone tip foward onto firewall
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 12-13-2010 at 09:38 AM. |
12-13-2010, 01:48 PM | #17 |
yes, i do
Re: cab weight??
Well the truck is still assembled. But thats good food for thought
