12-12-2010, 04:58 PM | #1 |
68 C 10
Smooth firewall
Sorry for the dumb qustion but when you shave the firewall and fill the holes at the heater box this just does away with all heat and defrost correct no need to have them with no blower trying to decide if this is what I want to do on my 68
Posted via Mobile Device |
12-12-2010, 05:06 PM | #2 |
Tot Roddin'
Re: Smooth firewall
Well you can fill the firewall and then run a Vintage Air setup which then pulls everything under the dash inside the cab. All you would have is four lines going into the cab.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-12-2010, 05:20 PM | #3 |
68 C 10
Re: Smooth firewall
Thanks Nate just starting on the truck going to ask lots of ? Ha maybe one day it will look half as good as blank slate! May smooth it and add vintage later
12-12-2010, 07:37 PM | #4 |
Tot Roddin'
Re: Smooth firewall
Thanks buddy!
Each build has it's own unique factors; can't wait to see what you can do with yours.
12-12-2010, 11:56 PM | #5 |
Re: Smooth firewall
Like this?
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
12-13-2010, 12:01 AM | #6 |
cwgreen1971
Re: Smooth firewall
12-13-2010, 04:49 PM | #7 |
68 C 10
Re: Smooth firewall
Thanks gkessru I love the look of that truck hope mine looks that good are the inner fenders painted or powder coated
12-13-2010, 07:37 PM | #8 |
Re: Smooth firewall
I bought the complete Master Cylinder/booster/bracket as a set on Ebay for about $200.
Inner fenders are painted with same paint as rest of truck. The hardest part of the inner fenders was to install them with no scratches. I dry fit everything before painting and then disassembled the entire front clip for painting separately. then I bolted the inner fender to the outer fender and installed them as a pair. Thanks for the compliments.
