Old 12-12-2010, 08:27 PM   #1
zane2513
zane2513's Avatar
Battery drain
Something is draining my battery I put a new battery in and two days later my battery is dead. What could be causing this? I don't have a radio. My wires are all a mess I need to rewire the entire truck. But is there some way to locate what is draining my battery? This just started this week never had a problem before some something changed.
Thanks for your help.
just rockin out in Oklahoma
oh and rebuilding my 66' stepside
66' Chevy LWB
in my own way!
zane2513 is offline   Reply With Quote
Old 12-12-2010, 08:45 PM   #2
1/2Dozen
1/2Dozen's Avatar
Re: Battery drain
do you have a test light? If so you take the negative cable off and use the test light as a connector from the negative cable to negative battery post. If there is a draw the lamp will light up. To find the draw start unplugging fuses or disconnecting circuits til the light goes out.
Hope this helps
66 suburban
51 Merc 2 door coupe
38 Chevy Business Coupe (gf's)
76 Airstream Sovereign
1/2Dozen is offline   Reply With Quote
Old 12-13-2010, 11:23 AM   #3
62gmc910
62gmc910's Avatar
Re: Battery drain
The aforementioned testlight method works very well, BUT sometimes if the draw is thru a relay you need to have the test light connected before disconecting the ground to keep the relay in the loop. (If you have the stock alternator it is prolly a stuck contact in the regulator)
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
