Old 12-13-2010, 01:06 AM   #1
Laid_Out_50
Laid_Out_50's Avatar
Mustang II Steering
How would I go about using my stock column with my mustang II rack and pinion
Laid_Out_50 is offline   Reply With Quote
Old 12-13-2010, 01:11 AM   #2
Scottshotrods
Re: Mustang II Steering
You need to cut your column out of the steering box.Once you have this done you will cut the steel tube up about 1 inch to expose the steering shaft.
Then you will need to make a bushing to secure the steering shaft from moving around.The bushing will need to pressed into the column and this will stay there.Once this is done you will need to buy a few steerig u-joints and a d/d shaft to hook up to your rack.It does take some work to do it the correct way.If you want the stock look this will have to be done.
Justin
Scottshotrods is offline   Reply With Quote
Old 12-13-2010, 02:20 AM   #3
cajundragger
better yet you could install a column saver.
http://www.classictrucks.com/tech/09..._u_joints.html
cajundragger is offline   Reply With Quote
