12-13-2010, 07:11 PM | #1 |
SSN 706
69 292 same as 66 292?
Is the engine in my 66 the same 292 engine as one in a 69.
12-13-2010, 08:23 PM | #2 |
Re: 69 292 same as 66 292?
no it won't be the same eng, but quite similiar. are you going more modern?
ron |
12-13-2010, 08:40 PM | #3 |
"Where were you in '62?"
http://www.chevyc60.com/the_engine_page.htm http://www.stoveboltengineco.com/ http://www.hotsixes.com/index.php?op...&id=2&Itemid=3 The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums Engine & Drivetrain http://67-72chevytrucks.com/vboard/f...splay.php?f=24
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 12-13-2010 at 08:44 PM. Reason: http://www.chevyc60.com/the_engine_page.htm |
12-13-2010, 10:01 PM | #4 |
SSN 706
No I was trying to find a power steering bracket. One on ebay the guy had ia 63 truck but the engine was a 69. Can't believe they are so hard to find.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 12-13-2010 at 10:02 PM. |
12-13-2010, 10:14 PM | #5 |
it should be the same casting. I don't know what year that they changed the length of w/pump on the v8s. I don't know whether or not that change was made on the I6's, that would be the only difference if there was a change. someone will say something on it
ron |
12-14-2010, 02:49 AM | #6 |
my power steering bracket came off a 1970 c-10 292. it bolted directly to my factory installed, original 292 in my 65. you wont have any problem between the years you mentioned.
12-14-2010, 04:04 PM | #7 |
Six in a row makes it go...
I believe they changed the size of the bolts that hold the flywheel on in '67 or thereabouts. Other than that and the carburetor I don't think there's a lot of difference.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
12-15-2010, 01:10 AM | #8 |
rare as hen's teeth!!
12-15-2010, 09:52 AM | #9 |
pretty sure there is a thread on here about converting the brackets for earlier 6's to the later integral head style. Not as nice looking, but way cheaper.
