Old 12-13-2010, 09:52 PM   #1
Truckbert-CS
Door Help, How to adjust the hinges
I could use some help with putting the doors back on.
Is there a specific way to adjust the hinges (which bolts to work with etc.)
I thought I saw a post on it a few weeks ago but I can't find it now.
Is there a chart that shows what happens to the door if you move the hinge a certain way?
Thanks for any help.
TW
Truckbert-CS is offline   Reply With Quote
Old 12-13-2010, 10:55 PM   #2
justincat
Re: Door Help, How to adjust the hinges
are they still in the same place on the cab? Or do you have to adjust them on the cab to. Anyways the side that mounts to the cab moves your door up, down, foward, and back. The side that meets the door just moves the door in and out. You should be able to play around till you get it right. adjust the cab side first, then the door side last
justincat is offline   Reply With Quote
Old 12-13-2010, 11:39 PM   #3
Truckbert-CS
The doors are from a different cab. The hinges were removed and painted.
I'll just have to do a little at a time.
Thanks for the info.
TW
Old 12-14-2010, 02:51 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
If you have good paint on the truck, tape all the edges with masking tape that way if you have contact you don't scuff it up.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-14-2010, 12:44 PM   #5
smn69
Try this thread:
http://67-72chevytrucks.com/vboard/s...ad.php?t=80129
It helped me a lot when I mounted all my doors fenders and hood.
smn69 is offline   Reply With Quote
Old 12-14-2010, 08:03 PM   #6
Truckbert-CS
Thanks for the link to the thread. It should help.
