12-14-2010, 12:14 AM | #1 |
1977 c10 rear drop how much to lower
I've lowered the front 5''. I'd like to have a slight rake to the front and Im not sure how much to lower back. Also when a post says 3/5 lowered is the 3 front or rear. And why do they lower 2'' more on one side. Sorry if it's a stupid question .
12-14-2010, 02:02 AM | #2 |
Re: 1977 c10 rear drop how much to lower
3/5 lowered is 3 front 5 back
12-14-2010, 10:12 AM | #3 |
The stock difference from front to rear is roughly 2 inches. Most go with the extra 2" in back to get the truck to sit level. If you plan to keep a stock rake, then you would want to go 5" in the rear. A more aggresive rake would rewuire less in the rear.
Smoke Tires, not Drugs |
12-15-2010, 12:56 AM | #4 |
Sounds like Im going 5 in rear sometimes flat or level rocker makes the rear of the truck look like its low and a full tank of gas don't help. Thanks for the info.
12-15-2010, 01:03 AM | #5 | |
Do you plan to run the same height front & rear tires? If so 5/5 sounds like what you need. If you stagger the tire height (w/taller rears), you might want a 5/7 drop (5= front drop; the 7 = rear drop).
12-15-2010, 11:50 PM | #6 |
Good point thanks for the info . Does a 6 or 7 rear drop need c notch?
12-16-2010, 12:30 AM | #7 |
A flip-kit alone doesn't need a c-notch unless your loading up the bed w/some moderate to serious weight. Add some shackles to that flip-kit, c-sections are definitely needed (even empty).
12-31-2010, 12:31 PM | #8 |
I went 5/5 I think its great.
12-31-2010, 06:23 PM | #9 |
4.5" front (2.5" spindles, 2" coils) 5" in back- flip kit
12-31-2010, 10:34 PM | #10 |
Grandpa in the rustmobile...
5-6 or 5-5 Will looks awesome
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-01-2011, 01:28 AM | #11 |
rear djm flip kit for 5 inches you will be happy. its 95 shipped
now if you want to do 6 inch rear drop the belltech kit with the notch is 265 shipped and its a very nice bolt in kit.
2011 CTS-V MODDED 2006 TRAILBLAZER SS TVS2300 BLOWER SOLD 2007 TRAILBLAZER SS 11.7@117 1.817 60' Wifes Daily Last edited by NORCAL SS; 01-01-2011 at 01:33 AM. |
