12-14-2010, 01:35 AM | #1 |
looking for inner fender support braces and windshield rubber info
I don't know what they are called.
They are flat steel and mount in the engine compartment with 4 bolts. The paint shop lost them and I can't figure out where to buy or what they are called exactly. I need to get windshield rubber also for a 1972 with the stainless trim Lmc was too small and windshield shop broke my original windshield and then got some other brand if I remember right was Precision, too big, wavy on the inside and cut up. Is Steele the brand to order? Also, door rubber, has anyone tried Steele's? Thanks for your help. Terri |
12-14-2010, 02:06 PM | #2 |
The Older Generation
Re: looking for inner fender support braces and windshield rubber info
Are you talking about the inner panel brace that stiffens the inner panel around the steering Column? If so there is only one on the drivers side. I have always used Precision brand rubber seals and have had no problems with them. Are you aware that there are two different seals for the windshields and rear windows with trim? It depends on which stainless trim you have, 3/8" or 5/8" lip. If you have the wrong seal for the trim you have it will not work. Welcome to the board... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-14-2010 at 02:07 PM. |
12-14-2010, 03:33 PM | #3 |
Welcome to the board! I've used Precision as well and had no problems.it's true,you need the correct seal for your year.What year is the truck?Is the stainless original?If not,you need to know what you have and match the seal to the trim.
12-14-2010, 04:21 PM | #4 |
I went for a couple of months with a windshield rubber problem. I thought I'd never get it in. The LMC rubber didn't even come close (As with almost of their junk).
I'm not sure if you are trying to install the windshield yourself but I was willing to pay just about anything to anyone that could do the job. I finally got a guy that could do it. He supplied a Sofseal rubber and it finally went in. |
12-14-2010, 10:20 PM | #5 |
I used Precision with no problems at all.
