Old 12-14-2010, 10:22 AM   #1
Navy Mechanic
Navy Mechanic's Avatar
Got to change the wheels part II
Someone aptly named these the "Slicer Dicer" wheels. Wheel shopping today. Going to replace with 17" TT-2 style wheels. If I go with the same width I currently have then back-spacing's not an issue cuz I'll get the same BS on the new wheels. But what if I go slightly smaller on the front? What's the best way to figure the BS I need?
Also...I've bought Summit parts for years. Anybody own Summit wheels? Any pro's or con's as far as quality, etc?
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline   Reply With Quote
Old 12-14-2010, 01:54 PM   #2
Navy Mechanic
Re: Got to change the wheels part II
Need some help! The bolt pattern on the above mentioned truck is 5X5 front and 5X5 3/8 back.....
Measured 3 times....searched on-line but can't find that particular bolt pattern. Anybody seen this?
Old 12-14-2010, 03:01 PM   #3
Alvin
Never Done?
Alvin's Avatar
http://www.wheelsmaster.com/rt_specs.jsp
Plug in what you have on the left side of this calculator and you can use the other side to figure out what new wheel/tire combo will fit.
As for the bolt pattern, never heard of it. Will a front wheel fit on the rear?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 12-14-2010, 03:12 PM   #4
Navy Mechanic
Thanks for the calculator. Guess I needed to measure a fourth time. The rear is a 5X5.5 (5X 139.7) pattern which matches some ford and dodge truck rear ends.
Old 12-14-2010, 04:34 PM   #5
Alvin
Never Done?
Alvin's Avatar
What a strange combo. Might have wound up with the salad-shooter wheels due to the difference in bolt pattern. Do the wheels have holes for 5x5 and 5x5.5?
Old 12-14-2010, 04:43 PM   #6
Alvin
Never Done?
Alvin's Avatar
Using this site: http://www.elites-wholesale.com/Shop...2384/SFV/32431
Select a wheel size in the menu on the left, then a color, and it will show you bolt patterns available. Coincidentally, the wheels I have (Torq-thrust Originals) are shown available in both 5x5 and 5x5.5 bolt patterns
Old 12-14-2010, 05:09 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
You may have to do an axle swap or rearend swap lol
NICE truck other than the wheels!
John
1999 Toyota Tacoma 4x4
Old 12-14-2010, 06:51 PM   #8
68Stepbed
68Stepbed's Avatar
Does it have a Ford 9" rearend?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-15-2010, 03:01 PM   #9
Navy Mechanic
It is a strange combo and I didn't know until I took the wheels off to verify the bolt pattern. The "Vego-matic" wheels on there now have dual bolt patterns for 5X5 and 5X5 1/2.
I'm no expert but I don't think it's a ford 9". It has a rear cap vice the removable front case. I'm going to crawl under to see if I can ID it.
