Off topic 04 Bonneville gauges
I have a friend that is having trouble with his 04 Bonneville gauges. He says he needs to send the whole cluster to someone to fix and found a company called Mr. Speedometer in Missouri that will do the work. Anyone had any experience with this???
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
~Rest In Peace~
Re: Off topic 04 Bonneville gauges
sometimes the circuit board goes haywire behind the dash cluster ,so maybe the speedo needs recalibration or repair to speedo head ,when i work at dealership for ford we used to sub work out to speedo shops to do repair if we didnt send them
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
blood type; Retumbo
sounds like a stepper motor lost it's baseline (zero setting)
many times I fix it by useing my scan tool with bidirectional commands to do a "sweep test" . usually costs the customer ~$30 and takes 10 minutes. |
Orrie I have sent a few dashs to a place in St Louis,Sorry I dont remeber the name but I had good luck with the repairs,Two were ditigal that had gone bad both came back working like they should.
Joe
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
Thanks guys I will pass on the info. Thanks to mods for moving to correct forum.
its all about the +6 inches
the little motors that run each guage needle is a common problem too. Call around to some local shops (not dealers) and see if they have a guy who fixes them. He have a cat that comes in and does them, he works stupid fast, pretty cheap, and we've never had him not do one properly.
