Old 12-14-2010, 03:54 PM   #1
Brad2thabone
Brad2thabone's Avatar
too much Z!
Has anyone ever clipped the front frame? Maybe from the front cab mounts forward? I had a shop do a Z but it ended up being way too much. I would show pics but some might faint.
Brad2thabone is offline   Reply With Quote
Old 12-14-2010, 05:01 PM   #2
875.3CHEVY
Re: too much Z!
lets see the pics
875.3CHEVY is offline   Reply With Quote
Old 12-14-2010, 05:10 PM   #3
Allensracing
Allensracing's Avatar
Re: too much Z!
are you asking about clipping in a replacement clip from the same body style, or from a different vehicle?
what truck do you own?
Allensracing is offline   Reply With Quote
Old 12-14-2010, 05:17 PM   #4
kunzy420
Re: too much Z!
post up some pics...
You could probably fix it yourself....its just metal
kunzy420 is offline   Reply With Quote
Old 12-14-2010, 05:30 PM   #5
Brad2thabone
Re: too much Z!
67 LWB
[IMG][/IMG]
Old 12-14-2010, 06:35 PM   #6
edflores
Re: too much Z!
Time for 26's??
Jeebus thats a bis ass z.
edflores is offline   Reply With Quote
Old 12-14-2010, 06:38 PM   #7
Allensracing
Re: too much Z!
so whats the problem? its easy to make them go up again.
either run it, or find another front frame section to do again.
Old 12-14-2010, 07:40 PM   #8
kev2809
low n' slo
kev2809's Avatar
Re: too much Z!
how much did he z it? i would just chop it off and re do it...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-14-2010, 08:36 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: too much Z!
Originally Posted by kev2809 View Post
..... i would just chop it off and re do it...
That gets my vote too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-14-2010, 11:56 PM   #10
Brad2thabone
Re: too much Z!
I asked for 3 inches. Then i showed up 2 days later and it was cut to lay with stock arms and spindles..i want to say at least 6 inches. Now there is talk of pancaking the crossmember just to get the motor lower.
Im probably just going to get it back cut it down and run a dropmember.
Thanks for the advice guys.
Old 12-15-2010, 12:09 AM   #11
kunzy420
Re: too much Z!
sweet jesus
What shop did this?? Id definetly re-do that
Old 12-15-2010, 12:25 AM   #12
jmedero
jmedero's Avatar
Re: too much Z!
Dude just chop it off and redo it.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 12-17-2010, 03:36 PM   #13
Mikedub82
Mikedub82's Avatar
Re: too much Z!
Thats alot of z.
Get Low
Mikedub82 is offline   Reply With Quote
Old 12-17-2010, 05:09 PM   #14
PBFAB.COM
PBFAB.COM's Avatar
Re: too much Z!
We make a dropmember that you can weld into a set of 2x4 rails if that's the route you go.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-17-2010, 06:56 PM   #15
The Big Green
Re: too much Z!
Wow, you only need 2in.
The Big Green is offline   Reply With Quote
Old 12-17-2010, 07:02 PM   #16
The Big Green
Re: too much Z!
Yea what he said, if you can drop that kinda cash then go DM, but the Z is cheap, and you get the same results minus the nice look of a DM.
Old 12-17-2010, 07:12 PM   #17
edflores
Re: too much Z!
No where close to the same result. Z's arent really cheaper either if you have a shop do it.
Old 12-17-2010, 07:45 PM   #18
The Big Green
Re: too much Z!
[QUOTE=edflores;4356027]No where close to the same result. Z's arent really cheaper either if you have a shop do it.
Both allow to lay out and my Z was a few hundred lmao.
Old 12-17-2010, 07:55 PM   #19
edflores
Re: too much Z!
[quote=The Big Green;4356088]
Laying frame is the only thing a z does.
The dropmember does A LOT more than that.
Correcting geometry, narrowing track with upgraded steering, and it take a few hours to do. Is your time worth nothing? Your skills? Welding equipment and electricity? Shop or yourself, I do not see a properly done Z as being cheap at all. And look what happened to the OP at a shop.... Obviously they didnt have the skills necessary. to complete a proper Z
Old 12-17-2010, 08:00 PM   #20
The Big Green
Re: too much Z!
I was merely stating a opinion here. Mines done correct and so is his weld wise lol. I don't need rack and pinion steering, or narrowed track width.
Old 12-17-2010, 10:22 PM   #21
dv8customs
dv8customs's Avatar
Re: too much Z!
The quality of the work doesn't look bad so just make them redo it and give you what you asked for.
dv8customs is offline   Reply With Quote
Old 12-17-2010, 11:31 PM   #22
texastrendz
Re: too much Z!
dont fill bad, i have been bent over by a shop before also. you need to take that hacked up mess back and have it fixed. hopefully they can fix it. looks like you are trying to tuck them 40's. lol. all kindin aside, that looks like a$$.
texastrendz is offline   Reply With Quote
Old 12-17-2010, 11:42 PM   #23
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: too much Z!
Wow.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-18-2010, 06:11 AM   #24
royo
royo's Avatar
Re: too much Z!
Does the front sheet metal fit
nickle and dime
royo is offline   Reply With Quote
Old 12-18-2010, 10:00 AM   #25
SevenOne
SevenOne's Avatar
Re: too much Z!
holy framehorns batman!looks good if it was a fork lift,j/k.Sweet truck thou.
SevenOne is offline   Reply With Quote
