Old 12-14-2010, 04:32 PM   #1
contracostastepside
66 fleetside brace measurements
I have a 66 fleetside that I need the measurements for so I can do the bedside repairs. Anyone have that little bit of wisdom?
contracostastepside is offline   Reply With Quote
Old 12-14-2010, 05:03 PM   #2
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: 66 fleetside brace measurements
Well I was told that the boxs are the same for say 62 up to the 66 > however it may be but they use different rails.... as the X frame trucks are wider in the frame. I have some specs on mine which is not a 62 from what I can tell.. but what measurements do you need?
GMR-PERFORMANCE is offline   Reply With Quote
Old 12-14-2010, 05:16 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
60-62, and 63-66 are quite different in regards to the cross sills and bolt placement.
if you have specs for 63 up that will help him.
Old 12-14-2010, 05:24 PM   #4
GMR-PERFORMANCE
Mark K sent me some specs sheets with bed wood and I just looked to see if they had them post , I could not find it, But I thought I had a sheet' sheet's showing the specs on all of the box types..
Old 12-14-2010, 09:28 PM   #5
contracostastepside
You guys are all so awesome. I am looking for the little pencil sized rod braces front the front of the bed. I have the old bent ones for the rear. So I can straighten and measure them and modify a set from a 56-60 set I purchased. However the fronts were missing when I got the truck.
Old 12-15-2010, 12:51 AM   #6
jonzcustomshop
1961 crewcab
al 4 pieces interchange, the rr, is the lf, and the lr is the rf...or something like that, I got mine off a couple different trucks.
there should be 2 holes in the crooss braces , about an inch apart for them to bolt to, I think that is for the factory adjustment.
on my 61 I had to bend the brace a little to get the wheel opening in just the right spot.
