12-14-2010, 05:28 PM | #1 |
Grandpa in the rustmobile...
Can anyone tell me the length of parking brake cable..
I am looking for a LR parking brake cable (Comes out of drum). Went to carquest and they had a couple diff. lengths. Without taking mine off measuring etc I was wondering if someone had theirs apart or knew the length right off.
1968 C-10 LWB Coilsprings 2wd He had a 40" and a 42" *think* THANK YOU! And if you have a used, BUT WORKING cable you'd sell, PM me or something.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-14-2010, 10:03 PM | #2 |
Re: Can anyone tell me the length of parking brake cable..
Anyone?..
12-16-2010, 10:27 PM | #3 |
Cmon! Someone has to be building a truck and can still remember where they put their old parking brake cables!!! Anybody
12-16-2010, 10:44 PM | #4 |
I don't know the measurement off hand, but I need to replace mine and only found one from LMC truck. Maybe the measurements are on their website.
12-16-2010, 11:00 PM | #5 |
Will look at lmc, let me know kidd, if you take yours off before would you caare to get me some measurements (would rather order local, just easier for me)
12-16-2010, 11:21 PM | #6 |
I ended up with several lenghts of stainless steel cable left over from work and it looked to be the same diameter, and since I too needed a new E brake cable, I made my own. I measured how long my old wore out one was, then I got some 5/16 round stock and carefully drilled a hole through it, stuck the cable through and then was undecided, so I used JB Weld to hold the ends on, then I made another and welded the end of the cable to the round stock. I don't know yet if they will work, but I don't see why not.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
12-16-2010, 11:23 PM | #7 |
Great idea^^
No, But i need the cable that comes right out of the rear brake drum and goes onto a bracket on the trailing arms..
12-16-2010, 11:32 PM | #8 | |
I just went and looked, it was Inline tube http://www.inlinetube.com/ Search for part # RE 416 Like I said, I'm not put back together yet, but these look-and more importantly-fit perfectly.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green Last edited by pritch; 12-16-2010 at 11:37 PM. Reason: added info |
12-16-2010, 11:43 PM | #9 |
Ok, thanks, Ive dealt with inline tube before, great product from what ive seen..
Really wanna buy locally (bought a cable from orielly and it was too short! its easier to return it to store rather than try to send it back via email/ups etc etc etc) Thanks!!!!! Anyone got a good used single cable theyd like to sell, would consider that also
12-17-2010, 09:17 AM | #10 |
Mine is a short wheel base, but I think those cables are the same. I have mine off right now so I will go measure them once it warms up a little. Unlike Oreilly's website the napa website actually gives you the measurement. I will let you know in a little bit.
12-17-2010, 10:31 AM | #11 |
My parking brake cable has been cut off, so I can't garuntee that its the correct lenght still, otherwise I'd get you a measurement.
12-17-2010, 11:29 AM | #12 |
The long one is for a leaf spring truck and the short one is for coil spring truck.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-17-2010, 12:08 PM | #13 |
My short wheel base coil spring cables are:
29 1/2" outside casing 40" cable This should be what you need. |
12-17-2010, 04:00 PM | #14 |
Old Skool Club
www.inlinetube.com sells these, but I don't recall lengths being mentioned in the specs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-17-2010, 04:24 PM | #15 |
THANKS VANCEMAN!!!!!!
Can anyone confirm swb/lwb is all the same cable?
