Old 12-14-2010, 06:01 PM   #1
kenm78
Broken Down
kenm78's Avatar
Heater/AC Blower Speed Resistor Noise
My 82 K10 Heater resistor is screaming! I't has been making this screaming noise intermentantly for the last year but today it would not go away. I have tried replacing the relay below it but the new relay causes fuses to pop so I assume the relay is bad from the manufacture. Is my resistor bad or my fan? When it isn't screaming the fan works great, but when it is the fan is slow and weak..
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 12-14-2010, 10:39 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Heater/AC Blower Speed Resistor Noise
I'm gonna say it's your fan motor, My Jeep started doing the same thing couple days ago. Take the fan out and put a few drops of oil on the shaft bushing, You can drill a small hole center of the bump on the other end of the motor then add a couple drops in that end. Put a dab of RVT Silicone over the hole to re-seal it.
Doing this will save buying a new motor during the holidays.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-14-2010, 10:53 PM   #3
kenm78
Broken Down
kenm78's Avatar
The motor doesn't seem to be making the noise. It sounds and you can feel the vibrations from the noise at the actual resister mounted in the ac avaporator housing . I can unplug it and it stops. Went back outside a hour or so ago and I couldn't duplicate the issue. It's the darndest thing. I will look into the motor like you suggest.
kenm78
1982 Chevy 4X4
Project truck
Old 12-15-2010, 01:21 AM   #4
bucannon
Salty Sailor
bucannon's Avatar
my fan has been making this noise off and on for years... i believe it is the motor
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 12-15-2010, 07:32 AM   #5
Restrorob
Restrorob's Avatar
When you unplug the resister your killing power to the blower so it won't make the noise.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 12-15-2010, 03:16 PM   #6
theprestongroup
Unplug the fan motor, and run a jumper wire from the battery to the motor. If the noise is still there its your motor.
theprestongroup is offline   Reply With Quote
Old 12-15-2010, 03:43 PM   #7
allengator
allengator's Avatar
most likely the fan motor has failing bearings...
thats why it slows down and draws more current
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-15-2010, 06:09 PM   #8
48cj2a
48cj2a's Avatar
There is nothing in the resistor to make noise...smoke maybe but no noise. The blower motor and the vent doors are really the only moving parts...has to be the motor bearings if you have not disturbed the squirel cage fan itself to alter its balance.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
