Old 12-14-2010, 06:32 PM   #1
gimmy 64
power steering box
can shttp://67-72chevytrucks.com/vboard/attachment.php?attachmentid=668388&stc=1&d=1292365695ome one identify this power steering box--it is on a 64 gmc i don't know what i did but here is the question-what steering box is this i am trying to find out so i can order the right parts to install my ididit column thanks
gimmy 64 is offline   Reply With Quote
Old 12-14-2010, 07:01 PM   #2
Oklahoma
Re: power steering box
looks alot like the one i put in mine, it was out of a 78 chevy 2wd. for about 50 bucks you can get a steering column out of a 93 s-10 and put that in there and save you around 300 bucks, thats what i did.
Oklahoma is offline   Reply With Quote
Old 12-15-2010, 12:54 AM   #3
Clark Davis
That gear box is called a saginaw found on most older chevy or gmc
Clark Davis is offline   Reply With Quote
Old 12-15-2010, 02:08 AM   #4
Captainfab
60-66 Nut
All I can tell you from the pic is that it is a '69-'87 GM truck power steering box. The '69-'80-'81 boxes had inverted flare fittings for the hoses, and the '81-'87's had a metric sized fitting with an O-ring. Then there are 2 or 3 different sizes/splines for the coupler to the steering column. It looks like you already have the coupler, so that wouldn't be an issue for you, unless you are going to change it to a universal joint or something else.
Old 12-15-2010, 05:08 PM   #5
Real_McCoy
Real_McCoy's Avatar
Not to hijack the thread, but ...
... do you have pics? Is there a thread on this swap?
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
