12-15-2010, 01:51 AM | #1 |
I'ma yearnin for some learnin!
Just to make sure (tires)
1968 chevy c-10 stepside
Stock tire size? When the person dropped the truck before me they put on a smaller size tire. So i looked at the faq and seen somewhere around the 225/75/15 range. I just want to make sure what would be the best size and just need to confirm this side would be good for my truck. Thomas
1968 Chevy C10 Shortbed Stepside |
12-15-2010, 10:36 PM | #2 |
Re: Just to make sure (tires)
Ttt
12-19-2010, 03:09 AM | #3 |
67-72 parts collector,…
What size wheels are you going to use?
12-19-2010, 05:45 AM | #4 |
15s
12-19-2010, 11:07 AM | #5 |
tire height will depend on how much it's lowered.
(front fenderwell clearance) I think a 225/75 (or 225/70) would be fine on a 7" wide rim. If you have a 8" rim a 235 might look better.
12-19-2010, 02:34 PM | #6 |
My truck is stock hieght
12-19-2010, 02:56 PM | #7 |
215-75-15 or 225-70-15 would be my first choice from calculations. 225-75-15 could work too.
12-19-2010, 06:30 PM | #8 | |
