Old 12-15-2010, 09:54 AM   #1
alsohim
Newbie Survivor
I am new to the forum and here is my Survivor. This is a 1970 C20 Custom Camper. Thanks for this forum. BTW the quadra Jet needs a rebuild and I have forgotten how. Anybody got a online resource with steps?
Kaleb A.
alsohim is offline   Reply With Quote
Old 12-15-2010, 10:13 AM   #2
Lee H
Lee H's Avatar
Re: Newbie Survivor
Welcome to the board. Nice truck with lots of options. Check out Cliff Ruggles or Sean Murphy Induction for your Q-Jet. Best get a new steel pump to carb line or you'll end up with a crispy critter.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-15-2010, 10:20 AM   #3
geezer#99
geezer#99's Avatar
Re: Newbie Survivor
Link for ya!
http://www.vetteprojects.com/kstyer/quadrajet.htm
Old 12-15-2010, 10:21 AM   #4
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Newbie Survivor
Welcome! You have a great truck to start out with and should have lots of fun bringing it back to life. I do agree with Lee, you need to replace that rubber hose between the fuel pump and the carb. Would be a bad thing to burn that truck>
alsriv2 is offline   Reply With Quote
Old 12-15-2010, 10:36 AM   #5
alsohim
Re: Newbie Survivor
thanks
Old 12-15-2010, 10:37 AM   #6
alsohim
Re: Newbie Survivor
Thanks!
Old 12-15-2010, 10:40 AM   #7
alsohim
Re: Newbie Survivor
Yea I am going to do just that. With the rebuild ill make a template from a wire hanger my only problem is getting the rounded off line nut at the carburetor.
Old 12-15-2010, 10:47 AM   #8
alsohim
Re: Newbie Survivor
Sorry another question, is there a sure way to determine valve size in the heads(1.96 or 2.02) also if this a 4bolt block?
Again TIA
Kaleb
Old 12-15-2010, 11:28 AM   #9
JohnC
JohnC's Avatar
Re: Newbie Survivor
Welcome to the boards from down the road in Noble, OK. Looks like a nice truck you have there.
If you get a chance check out the Oklahoma section.
JohnC is offline   Reply With Quote
Old 12-15-2010, 03:10 PM   #10
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Newbie Survivor
What is the CAMPER NAMEPLATE option on the SPID? What all is included in the CUST COMF & EQUIP option?
Nice option list.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-15-2010, 03:36 PM   #11
alsohim
Re: Newbie Survivor
I am trying to find out all the options, So far Heavy leafs (chevy used coil overs), Tool box/aux battery box, bigger radiator that I figured out so far. I would like to know which 350 this truck has.
Here is a better pic of the glove box.
Kaleb
Old 12-15-2010, 03:39 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Re: Newbie Survivor
[QUOTE=alsohim;4351137]I am new to the forum and here is my Survivor. This is a 1970 C20 Custom Camper. Thanks for this forum. BTW the quadra Jet needs a rebuild and I have forgotten how. Anybody got a online resource with steps?
Kaleb A.
http://www.florida4x4.com/tech/quadrajet/index.php
Oh, and welcome to the board...
LockDoc
Leon
Old 12-15-2010, 04:20 PM   #13
Lee H
Lee H's Avatar
Re: Newbie Survivor
Grab some numbers off the engine and heads. We can narrow down what engine you have a little. Casting number on back of block, drivers side by bell housing, Date code on opposite side, on the front of the block there is a small pad with stamped numbers, send them also. No way to tell for sure about 2 or 4 bolt main unless you pull the pan. The head casting numbers under the valve cover.
