BIG CHEVY 3600 LONGBOX
Size matters
1951 Chevy pickup 350 cid & 700R-4 with Walker Cobra radiator.
I thought I had enough room between engine and rad to keep the mechanical fan. However with air and the serpentine belt system the blade is about a half inch too close. Someone recommended a Taurus 2 speed fan and I bought one on Ebay. I wanted to use it as a pull but when fitting it I find it won't fit between the rad and motor. Does anyone know of a thin fan that might fit?
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Re: Size matters
Look up SPAL fans, some of them are thin and they cool great. Their website has specs and drawings, but you'll have to convert from metric measurements.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Spanked once
![]() Join Date: Oct 2006
Re: Size matters
I showed you this before and sorry I can't look at it now.. it's in storage and cold. What I remember is that I used a cut-off wheel to cut the mounting flanges on the radiator and inverted them to the motor side by welding them back to the other side of the radiator. And as Blue jeep mentioned the fan is a spal and also has flanges. I also fabbed a brace in the top front for the support.
http://67-72chevytrucks.com/vboard/s...44&postcount=6
The ole 350 budget build. |
