Old 12-15-2010, 12:42 PM   #1
bkquill
Rear axle removal
Hey guys, need a little help here. I have my 69' C10 on the jack stands and I'm about to remove the entire rear end off the frame. I've been told to use the spring compressor, I've been told that I don't need one.
I know some of you guys are great in giving step by step process for different tasks. So here I am asking for help for removing my axle. I know it's simple enough and straight forward, but I don't want to overlook anything and get a spring drilled into my noggin.
Thanks,
Brian
bkquill is offline   Reply With Quote
Old 12-15-2010, 01:06 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Rear axle removal
The rear axle as in the chunk and all?
Soak EVERY NUT IN PB BLASTER
Go back inside to get a snack or something
loosen U bolt nuts (will need HUGE braker bar/pipe)
Take panhard bar off
Take brakeline loose from the front of the T fitting on the pass. side of axle
Take parking brake calbes loose
Loosen coil spring perch on the bottoms (I left the tops alone when I did mine, just let em hang
Thats it I think, Good luck
John
1999 Toyota Tacoma 4x4
Old 12-15-2010, 02:24 PM   #3
bkquill
You ROCK Old Blue, thanks! I was thinking that's all there was to it, but better to be safe then sorry. It's my first frame off, so it's a learning process.
Thanks again, and I'm sure I'll be picking your brain again if you don't mind.
Cheers,
Brian
Old 12-15-2010, 07:04 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Yep, if the axle is hanging (frame on jackstands), then there is no tension on the springs. Just put a jack under the pumpkin and take everything loose then lower the jack and the rear will come down. penetrating oil....and lot's of it is your friend here, the longer it soaks the better. Also when you put it back together use new U-bolts and nuts. Good luck, and eat your wheaties, you'll need the strength!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-15-2010, 10:20 PM   #5
oldblue1968chevy
Yeah order some U bolts
And if you think you may wanna lower it in the future get a drop block/ u bolt kit or something
John
Old 12-15-2010, 10:41 PM   #6
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Come back on Sunday and we'll tell you how to remove the u-bolts that are rusted into the trailing arms.
Good luck.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 12-27-2010, 09:30 AM   #7
bkquill
Thanks for the tips guys! It dropped right out, and after fighting with it for a while with a 1" impact and a 5' breaker bar, I decided to work smarter. I decided just cut off the U-bolts.
Old 12-27-2010, 02:39 PM   #8
redbaron69
redbaron69's Avatar
you getting the hang of it already
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
