Blazer seat belts
May sound like a dumb question but this is the first K5 for me. My rear seat only has one seat belt that reaches the entire way accross the seat. Is this correct or should there be two individual ones like most vihicles? I have two little girls who want to ride back there just want to make sure I am legal.
needs more $$$
Re: Blazer seat belts
There should be 2 sets. There's 4 mounting holes on the bed floor in case you don't have the legs with mounts...
1970 2wd Blazer |
Thanks for the info, I have a bunch of stuff in boxes that I received when I bought my blazer, so I guess I need to start digging for the other belts.
![]() Join Date: Apr 2010
i think you could fit three back there 3 sets of belts
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer ![]() 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
Does anyone know if 3 in the back was ever a factory issued option on these? I have 2 on the four leg bench and want to add a 3rd, where is the middle belt attached?
![]() Join Date: Nov 2010
im not sure if it was factory or not, but i just doubled up the two center ones for the third belt, it was for my kids also so there was not a lot of weight on them.
Mine has 3 belts in the back and pretty sure it was factory.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
Finally got out to look at the blazer tonight. I only have the 4 post seat in the rear. I dont see where I can mount the other two pieces for the belts. Anyone have a picture they can show me where they mount?
Thanks |
needs more $$$
I don't have a picture, but my legs didn't have the nuts for seat belts either. I just bolted the seat belts to the same bolt as the legs themselves.
1970 2wd Blazer |
I have some of the seat belts bolted to the outer legs, guess I need to try and find some holes in the floor to bolt the interior belts of the seat. I am not sure If this is the original seat so hopefully they are there. The extra seat I have has 4 legs across the back but, it isn't ready to go in the truck. Thanks for the help.
needs more $$$
Ah... i get it. U should be able to bolt 2 more legs to the seat u have now. If u do that and match up the outer 2 legs, the 2 inner legs should be right over the threaded holes.
1970 2wd Blazer |
For anyone whos is interested still I found some pictures of how the seat belts bolt in on a original seat with the 4 post rear. This blazer even has the original 3 seat belts attached.
