69' GMC - slight issue today
i have a quick question for the experts here
![]() so about an hour ago i left work to go grab lunch, i jumped in the truck and she fired up fine. went to back out of my parking space and all of a sudden it was acting as thow it wasnt getting fuel and it died. it would crank over fine but wouldnt fire, when i would fire it wouldnt idle unless i had my foot on the gas and even then i couldnt get it ubove 500 RPM. sat there and cranked on it for a while then all of a sudden she came to life and ran and idled fine. i thought it might be the fuel filter but i just put a new one in. the truck has a new GM crate motor (350ci). it has the original points, not sure why they didnt convert it over but i dont think it was an electrical issue. what would cause it to do this so i can keep it from happening again? also, how hard is it to switch it over from points to electronic ignition thanks in advance ![]() here is the truck |
Junior Member
Re: 69' GMC - slight issue today
A float sticking could be one of the reasons.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
![]() Join Date: Oct 2007
Switching from points to HEI is not to difficult. 2 ways to do it:
Use your original distributor and install a electronic module it place of the points or Get and HEI distributor and just swap it in place of the old one. The other change is to run a power wire to the new unit (whichever you choose) that has a 12 volt power supply. The original power supply has a resistor that lowers the voltage to about 9 volts. It all depends on the look you want to go with and it can be done for well under $100, and it is worth it! |
do you think its better to just get a new distributer and plop that in? or does it matter? i'm sure you get the same results either way but i would lean towards the easiest solution.
and why is switching it over better? does it deliever a hotter spark and is it more reliable? i have never had to deal with points before so i applogized if i'm asking some dumb questions ![]() Last edited by silverado383; 12-15-2010 at 05:05 PM. |
#5 | |
The second answers are yes and yes. Points will just wear and burn and need to be replaced and adjusted at regular intervals, as long as the electronic module is good, there are no problems (they do go bad once in a while though). |
I am a Referee of life.
It took me an hour to change to HEI.I did plugs and wires also.There are some good write-ups in the FAQ's section.It actually took me longer to gather parets than to do the swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
A possibility is maybe the choke was on and died from being too rich, then when you started it up you had to open it up to clear all the fuel out?
Did you smell any gas while turning it over? I doute it was the distributor if it was running fine when you parked it.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
