Old 12-15-2010, 06:48 PM   #1
FL71C10
Rubber or urethane bushings
I am getting ready to redo the suspension on my truck and am not use if I should use rubber or urethane bushings on the control arms and trailing arms. Will the truck ride real rough with urethane? I want it to be tight but not teeth rattling.
Also, where's good place to get them. Napa only sells control arm shafts and they are pricey!
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-15-2010, 08:12 PM   #2
Re: Rubber or urethane bushings
It will be a more firm ride,but not really harsh.I like urethane in the suspension,but not the body mounts.
Old 12-15-2010, 08:42 PM   #3
FL71C10
What suspension parts can you replace with urethane besides the trailing arm bushings?
Old 12-15-2010, 09:59 PM   #4
FL71C10
anyone else have any thoughts on this?
Old 12-15-2010, 10:28 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
FL -= you can buy almost every bushing for these trucks in urethane
I agree - I am not a fan of urethane body mounts - just to stiff - if you just want to race the truck go for it - daily driver no thanks - they also can have a tendency to squeak more than rubber bushings
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-16-2010, 09:58 AM   #6
helldiablo
i went with urethane in the suspension and motor mounts... but not the body mounts they were still in good shape... i might change them later on... it did squeak for a little while like 1000mi but dosent any more..
helldiablo is offline   Reply With Quote
Old 12-16-2010, 10:34 AM   #7
lakeroadster
I prefer rubber bushings. I have used urethane on other projects and regretted it: harsher ride and noise issues.
lakeroadster is offline   Reply With Quote
Old 12-16-2010, 10:56 AM   #8
cadillacart
1972 C/20
cadillacart's Avatar
Same here, I have had bad luck with poly, I could not stand the noise. I have tried first dry graphite lubrication and when that didn't work, I greased everything up and it still squeaked off and on.
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 12-16-2010, 11:12 AM   #9
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Rubber worked for years from the factory... I would stay with them.
specialtyretail is offline   Reply With Quote
Old 12-16-2010, 11:20 AM   #10
scooterskoolkustoms
scooterskoolkustoms's Avatar
I prefer urethane. I have used both but just like the feel of the urethane ones my 2 cents.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 12-16-2010, 06:01 PM   #11
poff
I have urethane mounts everywhere in my truck, springs, motor mounts, body mounts, T-case. They are way more durable then rubber. Rubber these days is such poor quality. I can't hear anything over the exhaust so I don't care about squeaking. I do feel the cam lope through the motor mounts at idle but it's a truck not a Cadillac.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 12-16-2010, 06:38 PM   #12
LONGHAIR
Upper and lower control arm bushings
Sway bar bushings and end-links
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-16-2010, 06:50 PM   #13
Stubbs67
Stubbs67's Avatar
when you install them, grease them, and their pins/spacers washers etc with white lithium grease. haven't had any of mine squeak... to me it doesnt feel for firm, it just feels tighter and more responsive with urethane.
67 Short Step Project -My other wife, ya know... (she takes all my time and money and I don't even realize it)
88 Subaru wagon 4wd -Daily driver and workhorse
98 Subaru Forester S - Wife and baby wheels
My Build Thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=433751
Need step tail gate and bed front, driver door, both front fenders (both are bondo'd nightmares). can trade fleetside bed parts real straight (except sides) or pay some cash (i am pretty broke)
Stubbs67 is offline   Reply With Quote
Old 12-16-2010, 08:17 PM   #14
capev86
urethane lasts longer and tightens up the chassis (less flex than rubber) and should be fine if properly lubricated. i replaced the rear track bar bushings on my 72 burb c20 (CPP has the larger ones for the 3/4 ton track bar). planning to get their poly graphite body mount bushings as mine are rotted and i don't want to spend lots of money on rubber. looking for (extreme) long term durability as my truck gets nothing but the best and i'm not worried about a little squeaking (no helping that on a 38 year old truck anyway).
capev86 is offline   Reply With Quote
