th350 shift linkage 2wd vs 4wd eh?
thanks to Thealien for posting this pic, its exactly what I was google searching for with little to no results.
![]() The main bracket that is going from the framerail up and over the exhaust and connecting to the squared off U shape bracket on the trans, do these come in only one length? My 71 was missing its pieces from projects long ago, so I grabbed a setup off the local CL board. Got home, went to throw it in and I cant reach both the peg in the framerail, and the trans at the same time as seen in this pic. It doesnt appear to have been cut/welded, but it sure doesnt reach. Any ideas? It came with the piece that mounts to the frame, but that piece isnt identical to the shown above. The one I got is about 4" wide where the peg comes out centered, and has roughly 3" long legs that are made with a twist built into them. Thanks Erik |
Re: th350 shift linkage 2wd vs 4wd eh?
ok folks, nevermind. As seen in the pic above is what a 4wd setup should look like. The stuff I got is a 67-72 2wd. I've located a correct setup, but didnt have the cashflow on me to make it happen today. Maybe tomorrow I can find time to deal with it.
Then onto the other missing bits. ![]() Erik |
![]() Join Date: May 2006
wierd that a 2wd and 4wd would be differant
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Always on the hunt...
![]() Join Date: Sep 2006
Here's a side by comparison for future board searches. Mel
