Old 12-16-2010, 03:11 AM   #1
truckinlow
truckinlow's Avatar
Question Rear suspension
I have a 69 c10 longbed droped more than 6" and for some reason
my two rear tires aint centerd in the wheelbase so passagnger rear rubss
what could it be.
Maybe trailing arm bushins or traction bar
truckinlow is offline   Reply With Quote
Old 12-16-2010, 03:21 AM   #2
powerbench
powerbench's Avatar
Re: Rear suspension
if you have a trailing arm set up , does it have an adjustable panhard bar?
powerbench is offline   Reply With Quote
Old 12-16-2010, 03:30 AM   #3
truckinlow
truckinlow's Avatar
Re: Rear suspension
Yea I have trailing arms but not an adjustable traction bar its just the factory bar behhing the rearend
Old 12-16-2010, 03:48 AM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Rear suspension
If you're running more than 4" drop in the rear you should be using an adjustable panhard bar. This will help you center up the rear end. There are a few vendors here that sell them.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-16-2010, 03:57 AM   #5
truckinlow
truckinlow's Avatar
Re: Rear suspension
Thanks I figured thata fix it up I use cpp supension, any tips on how to adjust it properly while putting it on I wtouldn want to over adjust it
Old 12-16-2010, 04:54 AM   #6
FLEET72
FLEET72's Avatar
Re: Rear suspension
Measure the stock bar length, measure the difference between the two rear tire/wheel well clearance. Set the new bar shorter by 1/2 that amount.
Simplified example:
stock bar = 36"
Drivers side = 1" clearance
Pass. side = 0" clearance
set new bar at 35.5"
*YRMV*
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 12-16-2010, 08:55 AM   #7
cdowns
cdowns's Avatar
Re: Rear suspension
did you also invest n shock relocation kit to get the best performance out of your shocks???
Old 12-16-2010, 02:15 PM   #8
truckinlow
truckinlow's Avatar
Re: Rear suspension
Thanks fleet72
And I have not yet put on shock reloctors
Old 12-16-2010, 02:21 PM   #9
truckinlow
truckinlow's Avatar
Re: Rear suspension
do I measure the bar when its extended all the way out r in
