Which power steering pump are you guys using?
Im very limited on room in the engine compartment with the S10 chassis and steering and I have tried a couple but cant seem to get them in there with the 350. ThoughtS?
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, Last edited by texas56; 12-16-2010 at 12:40 PM. |
Re: Which power steering pump are you guys using?
I'm looking at the March Revolver style setup... Move the alternator over to the passenger side and the power steering up to where the alternator was. I think most are using power steering pumps from a 60's Impala? as the pulleys can be pulled off easier.
Just not paying the $1500 for it... will be making up my own. Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
I have a question,about power steering,that I am planning on putting on my 51 Chevy 3600. I have a magazine from Harmon's Classic Chevrolet. They have a conversion kit that gives all of the parts required. Also you have to modify your steering column. I have found a steering box,which they say,you can use a 69thru87 Chevy 1/2 ton steering box. I am also picking up a power steering pump,off of a 86 Chevy Van. Now my question,is there anyone out there,can tell me what steering column to use. I have now,a 72 Chevelle Wagon steering column,that previous owner converted to operate into the original steering box. I was wondering if I can use the steering column I now have which is a 72 Chevelle Wagon? Thanks,I hope I haven't put too much in my orignal question.
