Old 12-16-2010, 10:19 PM   #1
a.c.1
Raising truck in front
LMC states that original ride height is approximately 2" higher in the rear. Alot of folks lower the front and rear with nice results. Just throwing this out there - has anyone of yall raised the front to level the truck out and put some beefy tires on. I would love to see some pics if you got em handy. This just came to me in sleep last night.
a.c.1 is offline   Reply With Quote
Old 12-16-2010, 11:26 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Raising truck in front
Hmm
mabye BB springs or 1 ton springs...
John
1999 Toyota Tacoma 4x4
Old 12-16-2010, 11:47 PM   #3
a.c.1
How about 2 or 3 " raised spindles. I find 3" but no 2s'
Old 12-16-2010, 11:53 PM   #4
oldblue1968chevy
Got a link? Didnt know they made raised spindles..lol
Maybe a combo? How would you lift the rear of a 2wd truck with coil springs? Maybe wrangler lift springs?
John
Old 12-17-2010, 12:02 AM   #5
a.c.1
Idea is to leave the rear as is (stock height) raise the front 2" to level truck out. Give it just a little more robust look. Think i might try it. I'll keep looking for a link.
Old 12-17-2010, 12:23 AM   #6
FAC
This is something I am also interested in. I really like the look of a level truck and I would rather lift the front than lower the rear.
FAC is offline   Reply With Quote
Old 12-17-2010, 12:27 AM   #7
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
I am doing that right now....well when I buy the part...since LMC doesn't sell 1 ton parts you get the HD front coils that say "with 454"....don't know if that will raise it 2" but since I have a small small block I'm hoping it will..
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-17-2010, 01:12 AM   #8
mikewayne
You will rearly get any 2" spindles try 3" or 4"..... 3" will be better for you!!!
mikewayne is offline   Reply With Quote
Old 12-17-2010, 01:17 AM   #9
a.c.1
Thought of purchasing 3" raised spindle from 4 wheel parts source, then fabricate or try to find a 1" spacer for the rear coils. That ought to look tough with some decent tires. Hmmm the gears are turning in my head now.
Old 12-18-2010, 11:45 AM   #10
pooz911
pooz911's Avatar
if you have a sbc, you can install 1 ton springs. This will level out the truck, however with the stock bump stops, it will top out the suspension. I removed the stock bump stops and installed the thinnest ones i could get. I also installed a set of ball joint spacers to minimize the stress on the upper ball joint. I also installed a set of limiting straps so if I ever did get the front end off of the ground, it would minimize the stress on the ball joints. The only thing I should do is replace the front brake lines with longer ones.
I also have a 3 inch body lift installed and have been running this setup for 15 years.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 12-18-2010, 12:10 PM   #11
a.c.1
Pooz911 now thats a good lookin' truck. Got more pics? I've often heard 4 wheel drivers bash guys that do that. Its not that i want to drive through swamp or anything, i just like the stance.
Old 12-22-2010, 11:31 PM   #12
1NiceLonghorn
1NiceLonghorn's Avatar
My truck is a 3/4 ton with stock leaf springs in the back and 3/4 ton springs in the front. 3/4 and 1 ton springs are the same length. My spring shop put a 1 inch spacer in the bottom cup and it gave me a almost level ride.
1NiceLonghorn is offline   Reply With Quote
Old 12-23-2010, 02:59 PM   #13
pooz911
pooz911's Avatar
I tried to post some pictures with my initial reply. If you click on cardomain, you can check out the pictures of my truck.
Old 12-23-2010, 07:37 PM   #14
Prerunner1982
Prerunner1982's Avatar
Obviously my truck is not the same era, but as previously mentioned the 1 ton springs will work.
BTW... driveway is sloped in the picture.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-22-2011, 12:39 PM   #15
292farmer
292farmer's Avatar
sorry to revive old thread but do you know how long the compressed height of a 3/4ton spring is? ive got a 1972 c25 292I6, im trying to figure out if id get the 1-2in i want with just new 3/4ton springs as i dont know if mine have sunk since 72. do you think id see a lift with bb springs? im trying to raise front 1-2inchs thanks
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 01-23-2011, 02:04 PM   #16
72MARIO
72MARIO's Avatar
Fabtech and Rancho both make 3" lift coils. You can get BB and SBC coils so it rides nice. You will need to make a 1" balljoint spacer and flip the upper ball joint to the underside of the upper controll arm. I also added a 1" spacer under the coil spring. nd limiting straps to the lower controll arm to help out the upper ball joints.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-23-2011, 06:19 PM   #17
292farmer
292farmer's Avatar
wow nice truck thats the stance im looking for, do you feel 34in tyres will fit? do you have the three inch coils or the bb coils with 1in spacer? i misunderstood that part because that would make 4in with lift coils and spacer, and u list u got 3 inch lift. either way i go i'll need to build a spacer and swap the top balljoints around right? are the limiting straps what showing in second pic behind wheel looks like a red tie down? what did you use to build the ball joint spacer? thanks sorry for all the questions but been trying to find an answer for three months then you seem to answer all them and with pics in one post!!
Old 01-23-2011, 06:24 PM   #18
oldblue1968chevy
wow that truck is sweet ive seen it before but thought it was 4wd?!
John
Old 01-23-2011, 06:42 PM   #19
72MARIO
72MARIO's Avatar
You would have to throw a 3" body lift in to fit a tire any bigger than a 285 75 16
They call it a 33 but it measures a 32.5. it's close. I have fabtech 3" 1/2 ton sbc coils. and a 1" spring spacer from a 88 up I had to cut it to fit nice in the lower spring pocket. I also moved the lower controll arm down off the crossmember 3/16 " The ball joint spacer is a chunk of 1" plate cut out to fit on top of the upper ball joint. RANCHO makes 16 " limiting straps you can see in the pitcure.
2005 TAHOE DD
Old 01-23-2011, 06:51 PM   #20
292farmer
292farmer's Avatar
ahhh i see so look for lift springs for a 1/2ton,(couldn't find any for 3/4ton) i'll go bb as i use my truck as a HD work truck.(plus im adding a winch) did u use plate steel or washer to move lower arm down? im thinking i'll use plate steel and make it part of a skid plate assembly...think i'll go with out the 1inch spacer for now as i prefer the stuffed fender look unless u feel its necessary for rubbing issues? thanks again man!
Old 01-23-2011, 07:23 PM   #21
72MARIO
72MARIO's Avatar
I put in 3500lbs + most days and if does not squat much mabye 1/2". My spacers are 1 " flat stock.
2005 TAHOE DD
Old 01-23-2011, 09:07 PM   #22
292farmer
292farmer's Avatar
hmmm guess i'll be fine. did you raise your rear any?
Old 01-23-2011, 09:51 PM   #23
oldblue1968chevy
If you've got a GMC its prolly leaves, right?
John
Old 01-23-2011, 10:48 PM   #24
69CSTDawg
69CSTDawg's Avatar
just glanced over this thread may have missed it but can you "level" a 1/2 ton 2wd as well?
69CSTDawg is offline   Reply With Quote
Old 01-23-2011, 10:49 PM   #25
oldblue1968chevy
Yes
John
