12-17-2010, 04:54 AM | #1 |
What to do trans prob
my 73 gmc jimmy 4 inch spring lift 350 th350 np203.
trans has been acting up finaly lost 2nd gear today i have a th350 np205 out of a 72 with driveshafts but trans was last run 20 some odd years ago. so should i rebuild the np205 trans and instal or try and find a different trans |
01-04-2011, 08:45 AM | #2 |
Re: What to do trans prob
86 people read this and no one has anything to offer for help?
I wouldn't bother trusting an auto trans that has been sitting for 20 years. If you just wanna try to get it running again maybe find a good used trans and clean it up a little and install that. Then if you want maybe have the 350 rebuilt but the 205 should be fine without a rebuild. I have never had to rebuild a 205 or had one break. This was posted the 17th so maybe you have already figured something out. |
01-13-2011, 11:40 PM | #3 |
I think I'd hunt up a used TH400 that will mate to your T-case and run with it. Maybe have it rebuilt, mine was only $750 to rebuild. Its a little stouter trans and they are only a couple hundred bucks for a good used one. Make sure you get one that was recently pulled, preferably one you can see run and shift then pull it yourself or let them.
01-15-2011, 08:14 PM | #4 |
yea thanks i found a nv4500 3rd gear synchros are worn but for 200 i couldnt pass it up im gonna do a auto to standard swap n when im a little better of use that nv for a core on a reuilt one
01-20-2011, 12:24 PM | #5 |
Not to shabby! I wish I could pick one up that cheap! I'd do a swap in mine in a heartbeat!
'91 Burb, Fuelly, The Caddyshack '85 3+3 Duelly, Guzzler, Hank the Tank |
