Old 12-17-2010, 11:13 AM   #1
timjt
85 c10 need help, cold starting and high idle
I have an 85 c10 that won't stay on when I start it unless I keep the gas down for about 10 min, till its warmed up to normal running temperature. Problem with getting it started in the 'cold' only in the 40s.... ? I know there are threads about this but I can't find them. I also know this is probably a common problem but I'm still learning. Any ideas? Since its acting like its starved for fuel I tried adjusting the idle just for kicks and it helped a little but then once its running normally or its a warm day its idling too high
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 12-17-2010, 11:33 AM   #2
geezer#99
geezer#99's Avatar
Re: 85 c10 need help, cold starting and high idle
Sounds like a choke problem. Got a pic of your carb!!!
Old 12-17-2010, 11:33 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
your choke needs adjusting
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-17-2010, 11:38 AM   #4
timjt
Should get a pic of the carb on saturday. just too busy till then. My choke is on when I start the truck, but if I stomp the gas quickly then it opens up enough to start the truck but after about two seconds it starts shutting again, is there a spring or connection that needs to be adjusted? I need to get back under the hood and look at it (I've been under the truck working on the transmission the last few times).
Pics coming!!!
Old 12-17-2010, 11:51 AM   #5
geezer#99
geezer#99's Avatar
Take a pic before starting with air cleaner off of choke side and a pic of when warmed up running.
Old 12-17-2010, 11:52 AM   #6
timjt
Will do, thanks. Its a four barrel and the larger two aren't opening at all when its turned on. theres some sort of really strong vacume pressure holding them down or something...maybe send a pic of that too.
