Old 12-17-2010, 04:12 PM   #1
tdp67
tdp67's Avatar
Why doesn't my hood close right?
On my 67, the hood does not go down all the way in the back. I can push it down with my hand after it's closed. Is this normal or is something worn out?
tdp67 is offline   Reply With Quote
Old 12-17-2010, 04:17 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Why doesn't my hood close right?
It needs some adjusting or also, that is one of the main signs that the hinges are worn out.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-17-2010, 04:47 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
worn springs will cause this, as will worn rivit holes.
If you have nice paint, take steps to prevent paint damage.
Open hood.
Loosen the bolts that hold the hinge to the fenders.
have an assistant push the hood open a little further.
Tighten the bolts as the helper keeps it a tic further.
SLOWLY lower the hood. Keep an eye on the rear of the hood, it may rub on the cowl. If that happens, loosen the 4 bolts that hold the hood to the hinge and slide the hood forward a bit.
rinse and repeat
some cars not for use with some sets
actual results may vary
side effects may include diarrhea or constipation
Old 12-17-2010, 04:55 PM   #4
KEL
72 GMC
KEL's Avatar
nice disclaimer
KEL is offline   Reply With Quote
Old 12-17-2010, 04:58 PM   #5
russj67
russj67's Avatar
I had several of these trucks with the same problem. Someone on this site finally helped me fix it. Open the hood, loosen the hood hinge bolts on the fender and have someone push up on the hood from the front until you see the hinges lower in the back. tighten and check it. It worked for me!
67 Stepside
Atomic Orange
Fastburn 385
TH350
The wheels are
fronts are 255-45-18 with 5" bs. 18x8 wheel
rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit)
Budget: A method for going broke methodically.
You only live once!
russj67 is offline   Reply With Quote
Old 12-17-2010, 08:54 PM   #6
Longhorn Man
yeah... what he said!
Old 12-18-2010, 09:52 AM   #7
KEL
72 GMC
KEL's Avatar
isn't that what you said ?
Old 12-18-2010, 11:26 AM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Open the hood. Now move the front of the hood from left to right while watching the hinges. If the hinges move around on the rivetts, the hinges are warn out and the hinges need replacing. Tipping the back of the hinge back with warn out hinges is a temporary fix at best. The hinge will eventualy bend or come apart, and always at the most innopertune time, doing dammage to your new paint. The springs have nothing to do with pulling the rear of the hood down, they pop the hood open, assist in the lifting of the hood and hold the hood open. New GM hinges are still availible, so I would buy a new set now while you can. (If yours are warn out) The will be discontinued soon. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-18-2010, 12:11 PM   #9
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Why are the left side hinges $36 more than the right side? Just asking.
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
68lwb292 is offline   Reply With Quote
Old 12-18-2010, 12:34 PM   #10
Classic Heartbeat
GM bases their prices on the sales of a part. If a left side sells more than the right, then the left sells for less. They are that way on virtualy all of their parts. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-19-2010, 01:03 AM   #11
67C10BUB
67C10BUB's Avatar
Mine was the same way. All I had to do was loosen the hinge mounting bolts (to the fender) and push up on the front of the hood while it's open. Then, tighten the bolts while someone holds it up. This will push down on the the back of the hinge and make the hood sit lower.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 12-19-2010, 01:16 AM   #12
Zeke's Garage
Zeke's Garage's Avatar
That one is my favorite, and I always like to add:
'Your parents have to put it together'
Nostalgia'd hard!
Shawn
Zeke's Garage is offline   Reply With Quote
Old 12-19-2010, 01:20 AM   #13
67chevy1series
67chevy1series's Avatar
longhorn man that is a good one conctipation and diahera you should ad brain farts and severe displeasement
67chevy1series is offline   Reply With Quote
