12-17-2010, 08:49 PM | #1 |
Is this the right radiator?
I got this radiator with my front clip and I'm not sure if it's the right one for the truck. I dropped it into the lower holdowns and the realized that the tank is wider on the filler neck side than the other. Is it maybe a big block
radiator? How do I tell if it's 3 or 4 row? It's in ok shape, I figure I'll have to have it redone at a radiator shop but I don't want to do that and then find out it's not even the right one. My truck is a 350/350 originally (I think, bought it with no motor and no spid) Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-17-2010, 08:54 PM | #2 |
Re: Is this the right radiator?
Looks like some one has changed on of the tanks, should be same on both sides. Functionally it should work but you will need two different types of hold downs. Make sure it fits height/ width wise.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 12-17-2010 at 08:56 PM. |
12-17-2010, 09:02 PM | #3 |
Maybe it's a super rare part off of a 427 racing truck?
12-17-2010, 10:02 PM | #4 |
wow i've never seen one l9iek that before they should be the same size
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-17-2010, 11:51 PM | #5 |
The one on my truck is just like that, different size on the cap side.
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
12-18-2010, 04:56 AM | #6 |
Weard, i have never seen that ether but cant say of there factory. Mine has 2 wide tanks.
It looks to me like a 2 core but without looking down inside the rad cap opening i cant tell ya. Look inside and see if you have 1 2 3 or 4 holes (rows) front to back , don't worry about top to bottom , just look front to rear at one spot.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-18-2010, 10:35 AM | #7 |
6>8 Plugless........
It almost looks like it is for 73 up trucks due to the 2 different sized tanks.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-18-2010, 12:36 PM | #8 |
Ex-Minitrucker
You can tell how many rows it has by looking in the filler neck and counting how many holes there are from side to side.
68 C10 LWB 292 4spd 68 C10 LWB 250 3spd |
12-18-2010, 06:55 PM | #9 |
It is not a 4 row. I got a desert cooler for mine.
12-18-2010, 07:14 PM | #10 |
So one of the radiator holdowns is the wrong size and it's a little off side by side. I guess I need another radiator?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 12-18-2010 at 07:15 PM. |
12-18-2010, 08:35 PM | #11 |
The hold down go across the top of the radiator where the ends attach and they should be the same width, as long as they fit over it and it sit tight the mounts should be fine. My guess is your truck should be ok with a 2 core unless you live ina desert and do a lot of hauling or you have a bog block, if it wasn't GM wouldn't have put them on the trucks.
