Old 12-17-2010, 10:56 PM   #1
justincat
front drop dont look right?
I installed ece 4/6 drop and the back looks great but the front still looks like 3 inches high. Do the coils have to be in a certain way, or did i forget to line something up or what?
justincat is offline   Reply With Quote
Old 12-17-2010, 11:02 PM   #2
sjarrett71
sjarrett71's Avatar
Re: front drop dont look right?
pics might help
-Scott-
sjarrett71 is offline   Reply With Quote
Old 12-17-2010, 11:08 PM   #3
justincat
well I dont have a camera right now. But I know somethings not right looking at other trucks with this drop. It still looks almost stock up front I know the spindles and springs are right because I compared them up to my old ones. Its like they didnt set in there right or something.
Old 12-17-2010, 11:20 PM   #4
70cst
70cst's Avatar
Many with a 4" front drop have a combination of a 2 1/2" drop spindles with drop springs...I think. I will let others chime in.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-17-2010, 11:22 PM   #5
justincat
Yea I have 2 1/2 drop spindle, and 1 1/2 coils. I went and looked at it again, I think im just going to pull it apart, I must have not put the springs in right or something
Old 12-18-2010, 12:26 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
might be that the spring isn't seated into the pocket on the lower A-arm or in the crossmember. Or, maybe it needs to settle...have seen them settle an inch or more after driving a bit...
last....just making sure...is the drivetrain all in (engine/tranny)
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-18-2010, 12:54 AM   #7
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
You can't go by just setting it on the ground. It has to be moved back a forth a little.
prostreetC-10 is offline   Reply With Quote
Old 12-18-2010, 01:32 AM   #8
justincat
Yes the truck is fully weighted. I think they are not seated right. I guess my question is do I need to pull it apart and try to put the springs in different of will they seat there selfs once I get the truck running? Does the moving it back and forth a little seat them?
Old 12-18-2010, 01:50 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Take it back apart and check that the top of the spring is "clocked" correctly in the upper spring pocket.
You have to lay on your back and look up in the spring pocket to line them up.
Did you by chance install them upside down?
Keith
Convert to disc brakes.
Old 12-18-2010, 02:06 AM   #10
justincat
No there not upside down. Ill just take it back apart and see about the spring pocket. I remember seeing the spring pockets but maybe I didnt line them up just perfect. Its weird that both sides are like that though.
Old 12-18-2010, 02:36 AM   #11
DZL1
One day.....
DZL1's Avatar
Is it possible for you to borrow a camera cause you will definately get an answer to your question that way. Hope you can figure it out.
DZL1.
DZL1 is offline   Reply With Quote
Old 12-18-2010, 08:37 AM   #12
If they're seated correctly,they will settle from driving.That is what is meant by moving back and forth.
Old 12-18-2010, 09:51 AM   #13
cdowns
cdowns's Avatar
have you checked to see that the shocks aren't bottomed out and holding it up
Old 12-18-2010, 07:47 PM   #14
57larry
pics would sure help
57larry is offline   Reply With Quote
Old 12-18-2010, 08:15 PM   #15
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
I was able to rotate my 2" springs with everything together and the front end off the ground. Iused my cell camera to make sure the.springs were seated.....a 4" drop will be pretty noticeable ..lol
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 12-18-2010, 11:40 PM   #16
70jnktrk
70jnktrk's Avatar
X2 ...... I made this mistake when doing mine..
70jnktrk is offline   Reply With Quote
Old 12-20-2010, 12:10 AM   #17
atgilford
on your lower a arms there are seats that the springs sit in u have to make sure that the springs sit in the spots however it's ironic that both sides are even so there may potentially be something else wrong.
atgilford is offline   Reply With Quote
