![]() Join Date: Feb 2007
bouncy tach
Lowered 2002 PT Cruiser ONLY for mileage. 1969 Stepside 4x4 ( under construction ) ![]() |
Re: bouncy tach
I don't have a pic but on an auto guage there should be a wire for lights white, this hooks to the dash light circut, one switched power wire, red would go to the fuse block to a "switched" terminal, this means that whe the ign key is turned on the terminal has power, you need ether a test light or mulit meter to test them. one wire black to the neg battery. and Geen to the neg terminal of the of the coil.
Google up your tach if you don't have instructions handy and be sure your on the proper side of the coil
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#3 | |
Re: bouncy tach
huh?
![]() Join Date: May 2000
Re: bouncy tach
HEI or points?
Right before my HEI puked last year I would notice my aftermarket tach bouncing and occasionally losing all signal (returning to 0). Just a thought. Not sure on a factory tach as far as wiring goes, I'm sure someone else can chime in and help you there.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#5 | |
Re: bouncy tach
But thanks for your input ![]()
