Old 12-18-2010, 03:52 AM   #1
greasemonkey71
fog lights??
ok i fixed the alternator and the charging problem
i would like to add some after market fog lights i think they were 55watts
walmart has some sylvania lights for like $20 a light
alternator is internal reg. and 65amps i dont have a radio but i do have an electric fan
does anyone have fog lights?
would i be able to safely run theses lights without any charging problems
greasemonkey71 is offline   Reply With Quote
Old 12-18-2010, 08:50 AM   #2
FLEET72
FLEET72's Avatar
Re: fog lights??
Shouldn't be a problem now that your charging system is sorted out.
110watts (2 lamps) at 14V (driving voltage) is 7.85 amps.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 12-18-2010, 10:49 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: fog lights??
I'd recommend you wire them using a relay to eliminate any problems and get the most out of your lights.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-18-2010, 10:54 AM   #4
mrein3
mrein3's Avatar
Re: fog lights??
That is EXACTLY what I did. Use 10 or 12 gauge wire for the "high power" side of the relay (from the battery to the relay and relay to lights) and then you can use smaller 14 or 16 or even 18 to switch the relay on and off.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-18-2010, 01:46 PM   #5
greasemonkey71
Re: fog lights??
thanks guys
