Old 02-16-2002, 07:58 PM   #1
conoverbandit
Post 2 wd to 4 wd question
In another post on the 67-72 board someone posted that these model trucks have the hole already made into the frame for 4x4 axle in front. do the 73-87's also have them?, I'm getting a 78 crew cab 2 wd, and a 80 k-10, how hard is it to put the 4 wd axle under it?The crew is also a granny 4 how would I do the trans fer case? thanks ,
conoverbandit
71 GMC 3/4 ton converted to dually
75 chevy swb 4x4
78 pontiac trans-am----sold, so long old friend.....
87 Crew Cab 2x 454
93 chevy hi top conversion
conoverbandit is offline   Reply With Quote
Old 02-16-2002, 10:10 PM   #2
TRUCKPOOR
Post
conover, I'm not sure what you are refering to about the "hole for front diff or axle". 72 era 2x and 4x frames are different. I don't know if the frame rails on a 73 & up 2x are the same as a 73 & up 4x. As for the trans and transfercase - the output shaft is different on 2x transmissions, so you would have to use a 4x4 tranny setup. Hope this helps! Good Luck, Rob
TRUCKPOOR is offline   Reply With Quote
Old 02-23-2002, 12:51 AM   #3
jeff69cst/10
Post
the holes are there,however you have to remove the front crossmember and move it too. It is a lot of work
69 CST/10 350/400TH lwb fleet all original,1 owner
79 K/20 4x4 built & lifted
Sheridan,IN
69 CST/10 350/400TH lwb fleet,1 owner
79 K/20 built & lifted
85 K/5 4" lift 6.2 Diesel
Sheridan,IN
jeff69cst/10 is offline   Reply With Quote
Old 02-23-2002, 09:21 AM   #4
misfits
misfits's Avatar
Post
Its more bother than its worth.
misfits is offline   Reply With Quote
