12-18-2010, 02:25 PM | #1 |
Long or short water pump
I have a mid 70's impala 350 with a turbo 350 to put in my truck. It has all accessories on it, and I'd like to find out if I'm going to have clearance issues with the water pump. Is this a long water pump or short? If it's long, can I use it in my truck?
If not, I then have to get all new brackets and pulleys? Here are a couple pics of the motor. Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 12-18-2010 at 02:26 PM. |
12-18-2010, 02:28 PM | #2 |
Re: Long or short water pump
thats a long water pump. it will fit
12-18-2010, 02:39 PM | #3 |
Project Junkie! Fishing Poor!!
Long water pump, It will fit under the hood, however you will have to modify the headlight harness because the alternator is on the R/H side of the motor. You will also have to make a new fan shroud or convert to electric fans. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-18-2010, 05:31 PM | #4 |
Will the fan shroud hit the fan? Is that why I will need a new one?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-18-2010, 05:37 PM | #5 |
well, what does your truck have in it now? V8 or l6?
if its a V8, is it a long or short pump?
12-18-2010, 06:06 PM | #6 |
Originally v8 auto, I bought it with no motor or front end
12-18-2010, 06:38 PM | #7 |
The fan sticks too far out from the engine to use a stock shroud. I don't know whether or not it will hit the shoud or not, however it will set too far inside. WES
12-18-2010, 07:13 PM | #8 |
So you dont think it will hit the radiator, but maybe the shroud will not be right?
Maybe I should just get short wp and associated parts.
12-18-2010, 07:26 PM | #9 |
if it comes to close to the radiator, you can change the fan clutch.
a small block with a long pump is shorter than a big block with a short pump
12-18-2010, 07:44 PM | #10 |
no question, it's a long one
12-18-2010, 08:35 PM | #11 | |
12-18-2010, 11:41 PM | #12 |
I believe that the clutch fan is a bigger diameterthan the stock fan shroud opening as well.
12-18-2010, 11:46 PM | #13 |
OK, so I guess I'm in the market for new engine brackets and pulleys!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 12-18-2010 at 11:46 PM. |
12-19-2010, 12:15 AM | #14 |
its easier to get a aftermarket fan and a spacer to make it all work
12-19-2010, 12:21 AM | #15 |
So I could keep the brackets etc and just get an new fan?
12-19-2010, 12:23 AM | #16 |
I would stick with the long pump and brackets, but someone else might have a better reason to change.
12-19-2010, 01:02 AM | #17 |
Big Red - Now its a SWB!
yep its a long w/p, it can be made to work like stated above.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-19-2010, 11:26 AM | #18 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-19-2010, 04:01 PM | #19 | |
I would go to the trouble to change over if your wanting a factory correct appearing truck. you will have plent of space to work with, and a few minor details to make it work with a long pump. it will be a whole lot easier to find replacement parts later if you use the long pump. it will look more era correct with a short pump.
12-19-2010, 05:38 PM | #20 |
Watch out for your cornhole !
I've always just dropped a long pump engine in place on to the 6 cylinder type of engine stands. That sets the engine back a bit further to compensate for the longer front accessories.
12-19-2010, 06:02 PM | #21 | |
12-19-2010, 06:14 PM | #22 |
Yes it will clear fine. There's still enough clearance to allow removing and reinstalling the HEI if needed.
05-24-2011, 05:58 PM | #23 |
How far should the fan be from the radiator?
05-25-2011, 12:11 AM | #24 |
anyone?
