Old 12-18-2010, 04:05 PM   #1
Fat Mike
Fat Mike's Avatar
Question About Camaro Subframe?
What degree of angle is the subframe suppose to be at on a 59 frame. I read somewhere 7 degrees. Can't the camaro subframe be welded at the same height as the existing frame? What will happen if there is no dive in the camaro subframe?Also, need a measurement from the front body mounts to the centerline of the camaro subframe.
Fat Mike is offline   Reply With Quote
Old 12-18-2010, 05:29 PM   #2
troy54gmc
troy54gmc's Avatar
Re: Question About Camaro Subframe?
i did mine at the same height as the original frame. i think if you want it to sit lower you can z the frame s where you connect them.
troy54gmc is offline   Reply With Quote
Old 12-18-2010, 08:01 PM   #3
kaycee
kaycee's Avatar
Hey Troy how much did this drop your ride I am thinking of doing this but don't want it to drop to much.I was planning on doing the sub-frame up under the stock frame and then welding
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 12-18-2010, 09:16 PM   #4
troy54gmc
troy54gmc's Avatar
Hey Kaycee, here is a picture of the truck sitting on 17" stock dodge charger wheels. this is completly bottomed out with stock spindles. i plan on adding drop spindles to get the bumper on the ground. i think with a nice set of spring or bags it should sit at a reasonable level. there are a ton of pictures on here with guys welding on the way you are talking about. hope this helps.
Old 12-18-2010, 09:18 PM   #5
troy54gmc
troy54gmc's Avatar
heres a front shot.
