12-18-2010, 04:52 PM | #1 |
help! .....wiper problem!........ help!
im going crazy trying to figure out the problem..im finishing a complete body off restoration of my 72 cheyenne hugger 1/2 ton truck.installed nos wire harness,all brand new gm stuff. ...... so i installed the new wiper motor and it doesnt work.? i re installed the old one and it doesnt work. i removed the old one and tried to bench test it. when i turn the shaft then touch the wires to it (hot/ground) it starts up and runs the shaft 1/2 turn,i turn the shaft back 1/2 turn and touch the wires to it again it will turn 1/2 turn again. so i figured out the 1/2 turn is only a "return", but i cant get it to make a complete round. it is a 2 termanal plus ground. i have nos wire/fuse/switch/motor.
im still in dash assembly stage. ............. any ideas?
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
12-18-2010, 04:58 PM | #2 |
its all about the +6 inches
Re: help! .....wiper problem!........ help!
the wiper should have constant hot, and is turned on by adding the ground. That may be the problem on the bench test.
12-18-2010, 05:06 PM | #3 |
1990 chevy 4x4 with a 1940 IHC body |
12-18-2010, 05:06 PM | #4 |
not that i have a answer for you but here's a few pics of a old wiper motor i have laying around. Now you'll have a reference to go by. good luck!
12-18-2010, 05:25 PM | #5 | ||
yes, same type as mine...thx,dave
12-18-2010, 05:29 PM | #6 |
yote i have a similiar problem with mine also mine just stopped and i followed the bench test in the thread above and its ok ire=installed and nothing again. i wont drive it much in the winter so its sitting till i work on it again. on another thread mentioned about a "ground strap" from the motor to the firewall to ground the motor. below is another helpful thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=435162 and another http://67-72chevytrucks.com/vboard/s...archid=2039313
12-18-2010, 05:38 PM | #7 |
from the w/w motor to a scew close by, as i understood it thats how the w/w motor is grounded to work as it mounts are rubber but this info may be year specific i have a 67 and didnt find any, another said that the switch acts as a ground when you turn your knob the ground takes effect hope others will give their opinion on this ground thing im not a pro at all this myself just trying to help out here, good luck
1990 chevy 4x4 with a 1940 IHC body Last edited by peglegs; 12-18-2010 at 05:41 PM. |
12-18-2010, 07:03 PM | #8 |
Is the strap coming off the wiper motor to the upper screw in place? Be sure the ground is pluged in and have you tested with test light to see if you are getting power flow through the wiring harness? I had problem with 68 and actually had bad wiper motor, would wiggle, but nothing else, left it on for few seconds and it got red hot (litterally). Be careful, it can burn your new resto down.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-18-2010, 07:42 PM | #9 | ||
