Old 12-18-2010, 06:04 PM   #1
bif
Edelbrock 1406 re calibrate HELP!!!
Hello board. I need some advice. I live in beautiful Las Cruces New Mexico,around 4000+ feet above sea level. My problem is my new Edelbrock 1406 makes the 350 run rich (RV cam,full length headers).I bought the carb calibration kit #1487 with various jets, rods and springs. Now Leland at summit racing who sold me the kit said it would be idiot proof ,but now as I look down into the kit I don't have a clue where to start,or which jets,ors or springs to use. Any help any one?
Posted via Mobile DeviceThats jets,rods or springs to use
1969 chevy custom 10 lwb 350 3on the floor
bif is offline   Reply With Quote
Old 12-18-2010, 06:53 PM   #2
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: Edelbrock 1406 re calibrate HELP!!!
Strange, the 1406 is metered to be slightly lean in comparison to the 1405 600 CFM. I would try and go to the next step lean on the chart in the user manual. In your case it would be step 8. I assume you are having this issue while cruising (not wide open throttle).
screamin_c10 is offline   Reply With Quote
Old 12-18-2010, 06:55 PM   #3
screamin_c10
If you need to go lean in Cruise and Power (Acceleration) then use calibration step 7.
Use the chart above to mix and match the rods, jets, springs. You really cant screw up too much and can always go back to a base calibration...
Old 12-18-2010, 07:19 PM   #4
bif
Thumbs up Re: Edelbrock 1406 re calibrate HELP!!!
Thank you bill , I will give it a try and let you know ,mike
Old 12-20-2010, 10:47 AM   #5
dznucks
dznucks's Avatar
read my reply in this thread. this may help you alittle more.
http://67-72chevytrucks.com/vboard/s...47#post4360947
dznucks is offline   Reply With Quote
