Old 12-18-2010, 09:11 PM   #1
el_bole
Which steering colum to buy?
Hope all are well on here. I just picked up a 1961 apache....and want to put in a "new" steering column with tilt, signal lights arm, etc (with shifter on the floor =) ) Whats a good fit for this truck, aka easy to install and works well?
FYI I am 5'10 so no short columns will do lol. Any info would be greatly appreciated/
Thanks.....
el_bole is offline   Reply With Quote
Old 12-18-2010, 09:16 PM   #2
Greshampiglet
Re: Which steering colum to buy?
I used a 78 blazer column it bolted right in my 64 GMC and the wireing color coding was the same the total swap took me maybe 3 hours and I wasn't busting my a$$, I 'll send pictures if you need even though yours is a 61 everything should be the same
P1GLET
Greshampiglet is offline   Reply With Quote
Old 12-18-2010, 10:25 PM   #3
el_bole
Thanks for the reply. Yes I will take you up on wanting to see photos...
thanks again for the info....
Old 12-19-2010, 11:07 AM   #4
gulffishin
gulffishin's Avatar
me too on the photo's I've been wanting to swap in an auto column from a 67-72 for some time now
gulffishin is offline   Reply With Quote
Old 12-19-2010, 12:12 PM   #5
63lemon
63lemon's Avatar
P1GLET
Could you possibly send me the photos too?
Ich möchte vroom vroom
63lemon is offline   Reply With Quote
Old 12-19-2010, 01:22 PM   #6
willyp
willyp's Avatar
i used this IDIDIT Retrofit (made to fit), it bolts right in. tilt,turn signals and 4way flashers.
http://www.summitracing.com/search/?...20650010&dds=1
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 12-19-2010, 01:37 PM   #7
el_bole
You're right willyp the price of cool aint cheap lol. Man I like the interior of your truck....
Old 12-19-2010, 02:09 PM   #8
muddpile
muddpile's Avatar
Since I built my own firewall I wasn't limited by anything factory, so I used just a measured length Flaming River column and Billet Specialties mount. Worked great!
muddpile is offline   Reply With Quote
Old 12-19-2010, 08:59 PM   #9
gimmy 64
i bought a retro fit column from P.O.l. and it was an ididit column. still waiting on parts to finish from cpp. u-joint double d shaft etc. there add said input order before 12o and order will be processed that day and after you order they tell you it takes 7-10 days to process your order? WTF i have ordered stuff from summit on sunday and it shows up at my house on tuesday
gimmy 64 is offline   Reply With Quote
Old 12-20-2010, 12:40 PM   #10
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
One thing on the the Ididit set up , you can read my post but there have two versions one is more of a bolt in item than the other. Parts numbers are the same and really no way to get it right from summit as that is where I bought mine. Ididit swapped it out free of charge. There is a slotted section with a movable insert to bolt to the factory bracket, makes things a bit easier vs running sheet metal screws into the column but both will work.
GMR-PERFORMANCE is offline   Reply With Quote
Old 12-20-2010, 01:08 PM   #11
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Which steering colum to buy?
http://www.flamingriver.com/index.php/products
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-11-2011, 02:36 AM   #12
blackedoutharley
So the proper column is the 30" model?
blackedoutharley is offline   Reply With Quote
Old 02-11-2011, 11:57 AM   #13
Chevy Fleetside
Chevy Fleetside's Avatar
I got a nice Chevy Van column from the yard for $28. Was nice and tight and is even a tilt. I believe it was a mid 70's year van. They are pretty much the same from 73 up to 80. I lined it up and welded two nuts on the bottom of the column and that pretty much dose it. These are picture of the other column I had in it. I replaced that one becaue it was sloppy on the shifter. I have not taken any pictures of the new one yet.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-11-2011, 12:17 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
You can probably use one from an S-10 with manual trans.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
