Old 12-19-2010, 03:08 AM   #1
1971k567cam
1971k567cam's Avatar
door locks inop
Hey guys new to blazers and sight but working on my 1971 blazer. Found door locks work fine except when shut or when shutting them they wont work any idea what is wrong. I tryed holding button and shutting no change or even locking them when door shut no change? Any ideas i was thinking latch but both doors that woud be weird right?
1971k567cam is offline   Reply With Quote
Old 12-19-2010, 05:51 AM   #2
AlaskaMatt
AlaskaMatt's Avatar
Re: door locks inop
the doors only lock with the key. You can lock it from inside however if you push the knob down and then close the door they will pop up. A don't lock yourself out feature....
That may not be your issue, but knowing that little tidbit might help to isolate the issue.
On my driver side, I have to turn the key to lock and while holding it in the lock position push the button. Then it goes down all the way and locks. Goofy, but these things have lots of quirks and I swear 90% have to do with the doors.
Thanks,
Matt
My Website
AlaskaMatt is offline   Reply With Quote
Old 12-19-2010, 01:58 PM   #3
1971k567cam
Re: door locks inop
I can see that think my 67 camaro is similar but if door is shut cant lock anything at all door has to be open then locks work just fine makes no sense.
Old 12-19-2010, 07:55 PM   #4
john
member #16
john's Avatar
Re: door locks inop
Try pushing in on the door while locking. That relieves the pressure on worn parts and allows the lock to latch.
john is offline   Reply With Quote
Old 12-19-2010, 09:43 PM   #5
1971k567cam
Re: door locks inop
If that works then it would be a latch then right?
Old 12-31-2010, 02:43 PM   #6
bosco200
bosco200's Avatar
Re: door locks inop
My locks do this on my C20 to...the lock will only work if the door is open...its weird?
bosco200 is offline   Reply With Quote
Old 12-31-2010, 02:49 PM   #7
71swb4x4
71swb4x4's Avatar
Re: door locks inop
Originally Posted by john View Post
try pushing in on the door while locking. That relieves the pressure on worn parts and allows the lock to latch.
x2
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-31-2010, 07:22 PM   #8
1971k567cam
Re: door locks inop
If i push on them just a little they work now kinda weird but works
Old 01-02-2011, 05:07 AM   #9
old man jimmy
Re: door locks inop
sounds like your latches need to be adj. outward just a little.
old man jimmy is offline   Reply With Quote
Old 01-25-2011, 03:47 PM   #10
Olblue71
454 BB
Olblue71's Avatar
Re: door locks inop
I had the same problem with my '71 truck. A lot of lubricant and working the lock mechanism helped. I also had to take the door latch out and straighten it up a little. Seems to work now.
Olblue71 is offline   Reply With Quote
Old 01-25-2011, 06:54 PM   #11
bosco200
bosco200's Avatar
Re: door locks inop
How do you adjust the latch?
Old 01-26-2011, 07:36 AM   #12
old man jimmy
Re: door locks inop
Just loosen the 4 bolts on the latch, If I remember it's a 9/16 wrench. I usually take a felt tip pen and mark where they were just to get a reference point of how much I move them.
Old 01-26-2011, 09:45 AM   #13
Jurassic-1
Jurassic-1's Avatar
Re: door locks inop
I have found if the door latch is worn badly the rotating wheel gets in the way with the lock arm. The easiest way is to check it out and look for wear and lube it . if it shows wear replace it or if you are handy with a mig welder I have welded and refaced the locking arm to repair this problem. Usually you can tell if you have this wear by pushing in on the door as you try to locl it. This aligns the locking mech. with the lock arm.
Jurassic-1 is offline   Reply With Quote
Old 01-26-2011, 05:19 PM   #14
Jon Scully
Re: door locks inop
Does anyone have any diagrams/repair instructions for the door locks?
The locks on my 71 blazer 4x4 4spd-- are inoperable on both sides.
Door open-- It locks unlocks with the button--but not the key (i think the PO gave me the wrong door key)
Door closed-- does not lock with the button or the key.
One last thing-- Anybody know the key codes/types for the stock hardtops? I do not have a key and would like to get one.....
Does this mean i have to take the door panel off and do some adjustment......? I am sure I can figure it out, but this msg board is an amazing wealth of knowledge and resources-- And I do not want to re-invent the wheel lol!
Jon
Jon Scully is offline   Reply With Quote
Old 01-26-2011, 11:01 PM   #15
old man jimmy
Re: door locks inop
They came, one key fits all. Meaning same key for ign. doors, and hatch.
