CPP rear sway bar?
I was wondering if anyone has installed the rear sway bar that CPP sells and if so does it make much difference to the handling of your truck or is it something that just is not neccessary? May as well ask if there is a better set up than what CPP has to offer.
Grandpa in the rustmobile...
Re: CPP rear sway bar?
I read somwhere about putting a camaro bar on the rear....late 80's model camaro maybe I can find it
Does a rear bar help as much as a front bar does ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Rear swaybar-http://www.low69cst.freeservers.com/CamaroBar.htm http://67-72chevytrucks.com/vboard/s...t=47603&page=3
Big Red - Now its a SWB!
I saw a guy in the racing section that had a rear sway bar, not sure if it was cpp or not I will try to find out who it was so you can ask how much it helps out.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Here is the thread, if you look in post #4 you can see a pic of what 68 c-10 kid is running maybe shoot him a PM and see how he likes it.
http://67-72chevytrucks.com/vboard/s...d.php?t=433957
#6 | |
#7 | |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Project Heaven in my 67!!!
Where can I get the CPP rear sway bar???
lol....CCP
Interested too.
1969 Chevy c20(Miss Hackjob) |
Do the square trailing arms act differently than the stock trailing arms that make them unnecessary?
#13 |
#14 |
2WD Jimmy
![]() Join Date: Mar 2005
I think that you will find that most experts will tell you not to run a rear sway bar on trailing arms. They are designed to work best without one. Do a search on the Pro-Touring web site. Just trying to save you needless money. A good set of adjustable shocks would actually help and be money well spent.
Posted via Mobile Device |
#15 | |
#16 |
2WD Jimmy
Large sway bar on the front, 4-6 drop... good shocks all around. Re-do all the suspension... youll be great'. My BB should be slightly over 1000HP, Im not too worried.
#17 | |
Now factor in the weight of a big block with just a little throttle or a bump in the track and that truck is leaving the course at the apex of the turn! A sway bar at the rear will begin to equalize the rear load, reduce bump steer and help the front bar control compression of the suspension on the right front. |
#18 |
In my opinion after having them in there for almost two years the rear is definetly alot stiffer on the side to side movement. It feels very nice and tight. Those one piece square tubing from Early classics have urethane bushings and are a one piece so there is no flexing vs the stock ones being two pieces..
#19 |
here are some picts..
#20 |
#21 |
The exhaust is doug thorley headers and the rest was custom bent by a local muffler shop nothing fancy just staright duals with no xpipe.The tips come out the back under the bumper the piping before goes up and over the rear diff.
#22 |
![]() Join Date: Apr 2005
What part number did you get on the headers? What size are the primaries?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
