Old 12-19-2010, 11:45 AM   #1
cpetersen
cpetersen's Avatar
Tach and Vacuum question
I got this setup for $20 on Thursday in eastern AZ. Guy didn't know what he had. The 16yr old and I refurbished it yesterday and installed it. I think the tach needs to be calibrated, its not off by much.How do I calibrate it? But the vacuum didn't work. Did you guys use steel lines for the vacuum gauge?Name:  Unnamed.jpg
cpetersen is offline   Reply With Quote
Old 12-19-2010, 11:47 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Tach and Vacuum question
Not sure about the vacuum guage but on mine I used a barb and vacuum hose, I don't know what it came with originally. The tach can be zero'd using the screw on the back of it. That will bring you closer to actual.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-19-2010, 11:53 AM   #3
cpetersen
cpetersen's Avatar
How much vacuum are you running normally? Scary thing was i got this out of a c-50. I looked at the SPID in the glove and it showed it had bucket seats. It was a 68 truck. The seats were gone wonder how cheap it could have got them. lol
Old 12-19-2010, 11:57 AM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
awesome deal!
John
1999 Toyota Tacoma 4x4
Old 12-19-2010, 12:11 PM   #5
Lee H
Lee H's Avatar
I also run a barb and vac hose for mine. It's not real accurate but fun to watch. I think they are like the other gauges, close but no cigar. I'm interested in the adjustment for the tach. Mine reads about 400-600 to low. I do not remember the screw on the back. Does nayone have a picture of this? Later today I'll grab a flashlight and small mirror and see if I can find it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-19-2010, 12:28 PM   #6
cpetersen
cpetersen's Avatar
Yeah, there is a screw hole on the back. You use a small screw Phillips. Tach does seam very accurate. Needless to say, i'm not going to trust that tach and run the motor at redline. lol
Old 12-19-2010, 12:32 PM   #7
cpetersen
cpetersen's Avatar
This truck didn't have a chevy motor in it. Alot of the farm truck C-50's came with tall block 427's. interesting thought wonder if you can stroke those motors?
Old 12-19-2010, 03:07 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Tall deck 427's can be made into big inch motors, I know they can be stroked out to about 550 CI (not sure maybe bigger).
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-19-2010, 05:57 PM   #9
Jacfourteen
I don't have a stock vac gauge, I have an aftermarket one but it has a rubber vacuum line and it works fine.
Old 12-19-2010, 06:41 PM   #10
cpetersen
cpetersen's Avatar
How many pounds of vacuum does it run?
Old 12-19-2010, 07:01 PM   #11
dznucks
dznucks's Avatar
a healthy SBC should pull 17-20" of vacuum at idle. If you have a cam, your idle vacuum will be lower. the bigger the cam, the lower the idle vacuum.
The vacuum gage is a handy tuning tool. You will be able to watch when you power valve and secondaries are coming in.
dznucks is offline   Reply With Quote
Old 12-19-2010, 08:46 PM   #12
19seventeeCustom
$20, man Ill give ya 50 for it right now...lol JK
nice find.
19seventeeCustom is offline   Reply With Quote
Old 12-19-2010, 09:46 PM   #13
red71cheyenne
Back in the sticks
At idle it runs around 18-20 and drops as you get on it. There is a nice FAQ on GMC Pauls website about troubleshooting and tuning with a vacuum guage. I just like it cause it fills that hole in the dash and its fun to watch it move as I go through the gears!
2011 K1500 Suburban
2014 K1500 Pickup
