Old 03-07-2003, 11:59 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
OT speaker to amp connection
What kind of wire do i need to hook up 2 10" subs to a 120x2 Fosgate amp?? 12 volt? 10? 8? or is it something special
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 03-08-2003, 12:01 AM   #2
Hooter
My other Love
Hooter's Avatar
12 guage speaker wire should be adequate
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 03-08-2003, 12:01 AM   #3
pissonNOS
senior member
pissonNOS's Avatar
I would highly recomend going down to your local stereo shop and getting an amp wiring kit also I would use 8 guage wire but the kits come woth the ground remote fuses battery to amp wire everything u need
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 03-08-2003, 12:50 AM   #4
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
10 ga is pushing it, but will work, but 8 would be better, if you can get some wire that has a high strand count, that will be best. as for speaker wire, 14ga should work fine, just make sure the power wire is fused at the battery, and the ground wire is under 18 in in length, the shorter the better.
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
