12-19-2010, 04:07 PM | #1 |
cwgreen1971
Painless wiring
I am getting ready to head out to the garage and start wiring my truck. I bought the Painless #10206 kit which they say is pretty easy. It is all new to me. Does anyone have any tips or suggestions that may be helpful. I'm just doing the basic... lights/signals, ignition, dome light, horn, dash. I want to hide as much as possible...thanks
12-19-2010, 05:39 PM | #2 | |
Re: Painless wiring
69 Chevy 4x4 383 Power |
12-19-2010, 07:28 PM | #3 |
Re: Painless wiring
Yeah what he said!
Work from the fuse panel, working in the main bunch and as you branch off each circuit, lay them out roughly where they go, and fine tune the layout as you go. Most importantly, DO NOT CUT OR TERMINATE ANY WIRES UNTIL THE HARNESS AND BRANCHES ARE LAYED OUT EXACTLY WHERE THEY NEED TO GO!! They provide lots of zip ties, but I wind up using way more. It just makes it look neater. I also like to add chinese finger-type loom covering, P-clamps, and now is the time to add any wires or circuits you may want or need to make a completely custom setup! I've installed 3 of the Painless harnesses, and the more time you spend, the better the result. Get some heat shrink tubing and seal up all connections for a pro-look!
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
12-20-2010, 09:47 AM | #4 | |
2WD Jimmy
Re: Painless wiring
12-20-2010, 12:43 PM | #5 |
needs more $$$
Re: Painless wiring
You've already got some great advise. One thing I wish I did (and still am hoping to do) is get the black braided loom to wrap the wires. I used black tape and not only was it a PITA to do, it doesn't look very good where it is visible.
1970 2wd Blazer |
12-20-2010, 04:51 PM | #6 |
cwgreen1971
Re: Painless wiring
The "powerbraid" kit Painless sells is $220, that is over half of what I paid for the wiring kit!!!!! Where else can you get that stuff?
12-20-2010, 06:01 PM | #7 | |
Re: Painless wiring
12-20-2010, 07:13 PM | #8 | ||
needs more $$$
Re: Painless wiring
cwgreen1971~ The only places I was planning on running this loom is in the engine bay. Everything off the firewall's harness, so this is actually affordable now (at least in my case).
1970 2wd Blazer |
12-21-2010, 10:38 PM | #9 |
Re: Painless wiring
+1 TAKE YOUR TIME !!! It will pay off in the long run.
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL |
12-21-2010, 10:50 PM | #10 |
Re: Painless wiring
Fry's Electronics sells it by the roll. Fairly cheap.
67 Short Step Project -My other wife, ya know... (she takes all my time and money and I don't even realize it) 88 Subaru wagon 4wd -Daily driver and workhorse 98 Subaru Forester S - Wife and baby wheels My Build Thread! http://67-72chevytrucks.com/vboard/s...d.php?t=433751 Need step tail gate and bed front, driver door, both front fenders (both are bondo'd nightmares). can trade fleetside bed parts real straight (except sides) or pay some cash (i am pretty broke) |
12-21-2010, 11:17 PM | #11 |
PROJECT 7DEUCE
Re: Painless wiring
I did my blazer with a painless kit and it took about 4 days really taking my time..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
