12-19-2010, 05:36 PM | #1 |
Control Arm Question ???
I have a 67 2wd I am working on and I already have the Cpp drop spindles and front end rebuild kit but I noticed several people talking about using the control arms from the 73-87 model trucks . I was wondering what all has to be swapped out in order to use them and if they will work with the parts I already have ? The spindle kit I have come with the 73-87 upper and lower ball joints and outer tie rod ends as an upgrade . The truck already has front disc brakes so the main reason I am interested is the bushings can be upgraded . I haven't found any upgraded bushings for my 67 .
Demonspeed13 Last edited by Demonspeed13; 12-19-2010 at 05:39 PM. |
12-19-2010, 05:40 PM | #2 |
Re: Control Arm Question ???
is a rubber bushing an upgrade over a steel bushing?
12-19-2010, 05:47 PM | #3 |
You can get polyurethane bushings for the 73-87 but not the 67
Demonspeed13 |
12-19-2010, 05:49 PM | #4 |
the factory steel bushings in the 67 are better performance wise that polyurethane.
12-19-2010, 05:52 PM | #5 |
Ok I didn't know that they was metal . I have everything to rebuild my front suspension except upper and lower shafts and swap bar bushings but I saw a few people talking about swapping out the control arms . I didn't know for sure which would be better . Thanks for the info .
Demonspeed13 |
12-19-2010, 05:55 PM | #6 |
I have no clue why they swap them out. as long as there is no slop in the shafts, they are fine. make sure to keep them lubed. there should be a grease nipple on each cap
12-19-2010, 06:01 PM | #7 |
Ok cool thanks a lot for the help . I'm still learning a lot about these trucks lol . I'm glad I found this site .
Demonspeed13 |
12-19-2010, 06:19 PM | #8 |
Watch out for your cornhole !
The reason to swap them out is financial. A shaft and bushing replacement on the early arms is much more expensive that bushings for the later arms. Last truck I built I used a set of later arms because it was a couple of hundred dollars cheaper to rebuild them than the early arms would have been.
If you have a set of tight early arms I'd run them. Steel bushings are very durable and do not deflect.
12-19-2010, 06:21 PM | #9 |
I live in california, and all the arms here are always in good shape. I can certainly understand the cost savings issue.
I circle track raced for a while, and the guys with monte carlos paid a lot of money to get steel bushings to replace the rubber ones
12-19-2010, 06:23 PM | #10 |
My bro in law works at a parts store and can get me the upper and lower shafts from Moog for $176
Demonspeed13 |
12-19-2010, 06:25 PM | #11 |
do they need to be rebuilt? if there is no slop, there is probably no need to replace anything. I picked up a brand new set of bushings for my 66 truck about 18 years ago, then when I took them off I found out the stock ones still looked really good.
I still drive the truck, and I still have the brand new in the box moog replacements
12-19-2010, 06:30 PM | #12 |
I'm not sure if they have any slop in them or not . The only time I got to drive my truck before I started taking it apart was a rough and bumpy ride due to the heated springs lol .
Demonspeed13 |
12-19-2010, 06:37 PM | #13 |
67-72 parts collector,…
Did your truck have 73-87 stock spindles on it when you got it?
Just wondered why you went with 73-87 drop spindles and balljoints?
12-19-2010, 06:41 PM | #14 |
The spindles are for the 67 -70 , It's an upgrade kit that Cpp sells . It comes with the drop spindle and then uses the upper and lower ball joints and outer tie rod ends from a 73-87 . Suppose to be better design than what the 67 used .
Demonspeed13 |
12-19-2010, 06:51 PM | #15 |
it sounds like a kit that changes over to a 73 style drop spindle...
12-19-2010, 06:52 PM | #16 | |
Depending on which inner tie rods you have you may have to buy the tie rod adapter sleeves to connect your new 73-87 outer tie rods. The 65-70 inners are 5/8" diameter. The 71-87 outers are 11/16" diameter with a different thread direction. I've never heard of the 73-87 balljoints considered as an "upgrade",... although they are cheaper to sell.
12-19-2010, 06:54 PM | #17 | |
And that's not really necessary anymore. (Now that they make "year specific" spindles)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-19-2010 at 06:58 PM. |
12-19-2010, 06:54 PM | #18 |
Here is the link to the Cpp page for the kit I got . http://www.classicperform.com/Store/...ck/6370SSK.htm
Demonspeed13 |
12-19-2010, 06:58 PM | #19 |
I really just got this kit because it was the cheapest way to get the drop spindles and the other components to rebuild the front end .
Demonspeed13 |
12-22-2010, 12:35 AM | #20 |
does any one know if the 67 drag link will work with 73-85 inner tie rods? sorry i dnt mean to take over your thread. bt i dnt knw how to post my own
12-22-2010, 01:42 AM | #21 |
I think it would be a lot of work . The stock inner tie rods from the 73-87 are a lot bigger than the 67-72 . You would have to drill it out and prolly make some kind of spacer . I wouldn't think it would be safe . It turns out that my truck already had the 73-87 control arms and steering linkage and I didn't notice it til last night .
Demonspeed13 |
12-22-2010, 02:00 AM | #22 |
Thanx so it probally easier to change the drag link from a 73-85.. but will it fit the 67 pit and idler arms?
Posted via Mobile Device |
12-22-2010, 02:10 AM | #23 |
I used 73-87 steering parts (drag-link & tie-rods) w/my 68's factory idler & pitman arms.
12-22-2010, 06:12 PM | #24 |
Thanx scoti. And speed demon did u end up using your 67 arm or did u gt 73-85 ones? Which one r better?
12-22-2010, 06:32 PM | #25 |
I didn't realize when I posted the thread that it already had the 73-87 control arms on it . I didn't look close enuf before posting I guess lol .
Demonspeed13 |
