Old 02-18-2002, 07:13 PM   #1
Aaron's 79 C10
Post Anybody have a 6 speed?
I want to go from a th350 to t56 6 speed is that even possible in a 2wd 79 c10?
1979 C10 with a 355
Aaron's 79 C10 is offline   Reply With Quote
Old 02-24-2002, 07:40 AM   #2
BEN67EL
Post
aaron youd be better off with a 700r4 since its a drop in the 56 is a hydraulic clutch and the kits to do it are 600-1000 to do it later
i just love driving my 67elcamino and my trucks
BEN67EL is offline   Reply With Quote
Old 02-24-2002, 10:43 AM   #3
u2slow
Web Wheeler
u2slow's Avatar
Post
I had a T56 for some time. Due to a money crunch I had to flog it to my buddy who installed it in his '80 Cutlass.
The biggest hurdles are the flywheel and clutch. You can use the factory flywheel (93-97 Camaro/Firebird) only if you are using a 86-up SBC with a one piece rear main seal. Otherwise you need to buy a custom flywheel from Centerforce (read $$$). My buddy bought the GM master/slave assembly and adapted it to a truck clutch pedal and - somehow - got it into his car (it used to be auto).
He also had to build a crossmember and get the driveshaft shortened. No speedo either since the tranny is electronic, and the head unit is cable driven.
He's driving it now. He loves the Overdrive 5th and "Pull-me-over-drive" 6th! Especially since he runs 3.42's and 26" tall tires.
[This message has been edited by u2slow (edited February 24, 2002).]
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
