Old 12-19-2010, 09:19 PM   #1
alsohim
Amp Gauge Hook up
As my memory serves the Amp gauge works from indirect current on the factory gauge. My Gauge is pegged to the left and I would like to trace and fix the gauge. Where does it tie in?
Thanks,
Kaleb
alsohim is offline   Reply With Quote
Old 12-20-2010, 02:03 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Amp Gauge Hook up
There are numerous posts in the electrical forum on this subject but in a nutshell, There are two small wires that run to the ammeter gauge. One runs from the plus post on the right fender well through the firewall plug into the cab harness and to the key switch and from there to the dash cluster plug at pin 1.
The other wire runs from the three way junction of the alternator, battery and regulator
through the firewall plug and directly to the dash plug at pin 12.
As you can see from the diagram below these two wires run through two fuses that are 4 amp to protect the gauge in case of a short or voltage overload. These fuses are about 90% of the cause for the ammeter malfunctions. They are located in the harness that runs across the radiator core support, one on each side in little football shaped containers.
Name:  HEI and stock wiring..jpg
The wires are located at the bottom of the diagram and vertically on the right side to the fender post.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-20-2010, 01:28 PM   #3
alsohim
Sorry I am new to the forum and can't find the "Electrical Forum". I could use some help finding it.
Thanks,
Kaleb
Old 12-20-2010, 02:33 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's the home page link. It's at the top of every page. Scroll down to the second section and the electrical forum is the third one down.If you surf through the electrical forum pages you will find threads on everything electrical on our trucks.
Welcome to the forum. Great people on here.
http://67-72chevytrucks.com/vboard/index.php
VetteVet
Old 12-20-2010, 03:50 PM   #5
alsohim
Yes it is a good forum! and was refered to it by by another great forum Suzuki LC/C90 forum.
Thanks,
Kaleb
Old 12-20-2010, 08:55 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
flames make anything cool!
