Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 12-20-2010, 02:36 PM   #1
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
72 blazer stuff WIW
Just tryin to get a idea on what this stuff is worth. I would like to see it go sometime soon just dont want to give it away and dont know what to ask for it. thanks for your help, and I will post pics when I get a chance.
72 blazer single wall top with one small crack on the left side past the rear window and crack below and above the latch on the rear hatch
72 blazer rear bench seat clean, it does have a small tear about the size of a dime on the seat.
72 blazer front and rear diffs drum to drum and hub to hub complete. Gear ratio is unknown, but worked perfect before pulled 2 weeks ago.
72 blazer 6 lug 15in wheels set of four. minor surface rust that can be taken off with a wire brush or steel wool.
72 blazer mostly complete wiring harness minus the rear wiring for the tail lights.
flex plate from a 72 chevy small block
holley 600 maybe a 650 dont know with a manuel choke, will need to be rebuilt
72 blazer stock front leaf spring no Ubolts but with hardware that holds it to axle.
84 rear driveshaft out of chevy 3/4ton scottsdale.
72blazer_mud_bogger is offline   Reply With Quote
Old 12-20-2010, 02:38 PM   #2
72blazer_mud_bogger
Re: 72 blazer stuff WIW
a few more pics, and will post better pics of the top once I get a chance to clean the snow and branches off
Old 12-21-2010, 03:40 AM   #3
72blazer_mud_bogger
any help from anyone on this
Old 12-21-2010, 06:55 PM   #4
sharpie1972
Here's a list of how I price my parts, might be a little different in your area since most of these won't be shipped local demand dictates price. Hope they help, Sharpie
Single wall top. Condition of hatch is a big factor. $200-500.
Blazer rear seat. Will also work as #2 or #3 in a 3 seat suburban. $150.
Front and rear diffs. Gear ratio is important, but should be easy to find out. $300-400.
Ralley wheels. $75. More if you have centers and trim rings.
Wiring harness. Depends on splices, cut wires, etc. $35-75.
Flex plate $20-30.
Holley carb. $50.
Stock leaf springs. Occasional buyer that wants to go back to stock. $50-75.
84 Rear driveshaft. Usually scrap weight or save for parts. $25-50 if someone needs that exact shaft.
sharpie1972 is offline   Reply With Quote
Old 04-08-2011, 01:36 AM   #5
72blazer_mud_bogger
thanks sharpie
