Old 12-20-2010, 09:19 PM   #1
turbotravis
Question 67 light wireing
hey all,,, i am new here so i am not to sure how to gather info yet so i will go ahead and ask some??? i am trying to get my turn signals and running lights sworking on the old truck. i need a wireing diagram i guess. so far the lefrt blinker works but that is it. the right blinker doesnt even make the flasher click. any advise. i am what alot of people consider very mechanical but to be honest lights throw me for a loop. i do body work, rebuild motors, rebuild trannys and diffs, you name it i have done it but ask me to wire up some trailer lights and i will be pulling my hair out in no time.thanks
turbotravis is offline   Reply With Quote
Old 12-20-2010, 09:55 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 67 light wireing
Go to "Forums" above then scroll down to "Electrical" and then then scroll down to diagrams.
Is the wiring intact in your truck? If it's all messed up, you may want to buy a wiring kit to make life easier. Also, make sure all your ground straps are new and have good clean connections. I had to add several in my old truck to help the lights work better. Amazing the difference.
Here's a site diagram: http://outintheshop.com/faq/wiring/wiring.htm
68gmsee is offline   Reply With Quote
Old 12-20-2010, 10:44 PM   #3
turbotravis
thanks thats what i was needing..
Old 12-23-2010, 12:43 AM   #4
turbotravis
ok i posted in electrical forum with no responce//// i need to know if 67 had running lights? when i pull the headlights on they go off. but they work if you pull the light switch out to the first position with the head lights off,
Old 12-23-2010, 01:06 AM   #5
long67
long67's Avatar
No running lights on 67
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 12-23-2010, 01:07 AM   #6
McClinton527
McClinton527's Avatar
could be the turn signal swith in the column behind the steering wheel they go out on a lot of these old trucks and cause all kinds of lighting and turn signal problems.
McClinton527 is offline   Reply With Quote
Old 12-23-2010, 01:19 AM   #7
turbotravis
ok this is what i was after.. i guess they have park lights but not running lights? seems like the tail lights would come on with the front running lights.... so they dont have tail lights with the headlights on? seems dangerous
Old 12-23-2010, 02:19 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
added later... after reading through here awhile i ran across a post that said running lights didnt start until 1968.. is this true? and if so i am guessing its only for the front lights?
I saw your post and I quoted the second part above which indicates that you solved your own problem which is why I didn't reply and probably why no one else did as well.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-23-2010, 02:29 AM   #9
long67
long67's Avatar
You have tail lights with park lights on and you have tail lights with head lights on. When headlights are on you do not have park lights on.
Mark
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
