Old 12-20-2010, 11:36 PM   #1
jakeblues652
jakeblues652's Avatar
am i drunk? it looks like it!
so my truck's steering box is SLOPPPY! when you drive it, the people behind you must think that we just came from a party every time. is there an adjustment on the worm gear to tighten it up a bit? ive adjusted them on tractors, but never on a truck. i checked the tie rods, they were tight, i checked the ball joints-they're good too. it seems like all the slop is just because the box is loose.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-21-2010, 12:02 AM   #2
67chevy1series
67chevy1series's Avatar
Re: am i drunk? it looks like it!
there is a rag joint that could be the problem o rit could be the pitman arm
67chevy1series is offline   Reply With Quote
Old 12-21-2010, 12:03 AM   #3
bosco200
bosco200's Avatar
I had this problem on my 72 C20...I put a new coupler in and I turned the wheels in a bit and now it drives perfect.
bosco200 is offline   Reply With Quote
Old 12-21-2010, 12:14 AM   #4
AirSpeed
AirSpeed's Avatar
The steering box could also be loose on the frame, the mount is riveted to the frame and those rivets come loose sometimes. There is also an adjustment on the steering box. I have read that it's best to adjust it in a vise, I can't remember the reasoning but as I remember it the article I read had some string reasoning behind it.
AirSpeed is offline   Reply With Quote
Old 12-21-2010, 12:29 AM   #5
jakeblues652
i had someone look at it while i turned the wheel all the play it had, and i definatly looked like the steering box.
Old 12-21-2010, 12:34 AM   #6
Rack Man
On my 70 there is a set screw on the steering box with a lock down nut on it.
You can adjust it and that takes the play out of your steering....
"Loosen the locknut on top of the box with a 5/8 wrench while using a screwdriver to keep the middle screw from turning. Now, turn the screw clockwise to remove slack and then hold it while tightening the locknut back up.
Don't tighten the screw too much though, or you'll get a stiff spot in the middle of the steering travel. If so, back it back off enough to make the steering turn smoothly lock to lock"
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-21-2010, 12:39 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Check this recent thread: http://67-72chevytrucks.com/vboard/s...d.php?t=435037
If the adjuster helps your problem, at best you will buy a little time before replacing the box.
But the box will need to be replaced soon.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-21-2010, 12:48 AM   #8
jakeblues652
thanks for the info!! this trucks more of just going to be a weekend driver until next october(ish) when i get my permit. otherwise, it dosent move without me in the cab. maybe i'll go to teeps(the local junkyard) and see what they have for steering boxes. its not like it could hurt to look, and if i find one thats tight, its free. that would be a score and a half.
Old 12-21-2010, 07:12 AM   #9
cdowns
cdowns's Avatar
improper tightening of that adjustment screw can cause catestrophic failure of the steering box
a replacement box is a better idea
Old 12-21-2010, 09:04 AM   #10
Shane
Shane's Avatar
that jam nut and set screw is not designed to take WEAR out of the box ... it's there to adjust backlash out of the worm gear when the box is NEW ... listen to STOCKER & cdowns on this one.
Shane is offline   Reply With Quote
Old 12-21-2010, 09:39 AM   #11
Sammy
I have had a box fail on me while driving. It takes no prisoners and gives you very little warning what-so-ever. Luckly I was only doing 3 MPH pulling into a parking spot. There was no over riding the non power steering it was stuck in a hard left turn and refused to return to straight ahead. REPLACE IT.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-21-2010, 05:37 PM   #12
dan76
I've heard of this happening to other folks.........take heed and replace it. But also check the rest of the steering gear.
dan76 is offline   Reply With Quote
Old 12-21-2010, 06:06 PM   #13
legendary
legendary's Avatar
I have had a box fail on me while driving. It takes no prisoners and gives you very little warning what-so-ever....
My parents were nearly killed because of this very situation. On the interstate, doing about 60 mph in a Plymouth Valiant - steering ceased to work, and they ping-ponged into the underpass (left.......boom......right....boom) then rolled over 4 times. My father had no control of the steering, and that was the cause of it. Thank God for God.
Edit: This happened in 1988
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 12-21-2010, 06:26 PM   #14
rusty baker
'70 C-10 Primer
rusty baker's Avatar
RM
Guess I'm lucky. Did this to mine about 10 years ago. No problems yet.
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 12-21-2010, 07:04 PM   #15
rsavage
rsavage's Avatar
Check to make sure that the 4 bolts that hold the box onto the frame are tight. I had a similar problem of wandering on my 4X4 even with new pitman arm, rag joint, drag link ends, tie rod ends, and a rebuilt PS box. Turned out that the box was loose. When I put it all together over a couple of days, I must have forgotten to torque the box bolts. Have someone turn the wheels back and forth slowly while you watch underneath.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-21-2010, 11:42 PM   #16
697498chevy
Steering was sloppy in my '69 . Guy at work told me to tighten this same slotted screw on the box . I did and now I'm worried . This was a few years ago . Looked on Auto Zone site and found only power steering boxes . Where can I get a good/safe one ? THANKS !
697498chevy is offline   Reply With Quote
Old 12-22-2010, 01:35 AM   #17
vectorit
What?
vectorit's Avatar
Save up a couple of hundred dollars and get a new rebuilt one.
Messing around with a 40+ year old steering gear is just asking for problems.
Believe me, I tried and it's just not worth the hassle.
Get a new one, and you can do the swap in 30 minutes.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-22-2010, 01:49 AM   #18
1969C10shortbed
My truck does the same thing. My box needs to be rebuilt.
1969C10shortbed is offline   Reply With Quote
